FAST 90 tb dbc problem
Old Mar 21, 2010 | 10:58 PM
scottie dont's Avatar
Default FAST 90 tb dbc problem
i have a 98 trans am with an 05 gto intake and a fast 90 on it. i've had it for about 6 months and lately i've started having problems with it sticking open. not wide open but enough to make the car idle at 4400 rpms. if i get out and push it back shut it'll stay normal (idling at 1050 rpms) until i flog (yes flog) the throttle. then its back to idling around 2400 rpms+. anybody else run across this issue and if so what'd you do? I tried to get ahold of FAST but they wont return my calls or emails. thanks for your info.
- Scottie
Old Mar 22, 2010 | 05:38 AM
69LT1Bird's Avatar
Have you disconnected the throttle cable and tried to duplicate the problem by moving the TB lever by hand?
Old Mar 25, 2010 | 12:45 AM
i've tried it by hand and i can get it to do the exact same thing. im not sure why its sticking theres nothing for it to hang up on
Old Apr 3, 2010 | 09:51 PM
SweetS10V8's Avatar
Some of the FAST 90s did this, they totally redesigned the 92mm's.
