deleting the vvt
I like the idea of VVT, and I beleive it will work fine on mild(small cam) applications, but if you want an aggressive setup, eliminate it. my.02
Every major auto manufacturer (including Ferrari, FYI) has implemented a VVT system of some type in their engines, so the benefit is obviously there. Just take a look at the GM High Tech article on the cammed L92 engine. The "large" Comp Cam that they use yields marginally more performance (like 5-10hp if that) over the "smaller" cams that were tested. All VVT cams of one sort or another are certainly small by most SBC guys standards.
I'll have a dyno chart up of my VVT LY6 before too long... coming from a cammed LS1, I like my LY6 a lot better.
If your building a drag only car its really pointless to add VVT imo. For any street car the ability to have more with less so to speak is a welcome addition and will make the car more fun to drive in general as the throttle response and pull from corners and roll on pulls will all be noticeably improved. So what this means is if you take two identically prepped manual trans street cars yet one has VVT and one doesnt. You roll away from the light up and then hammer it the VVT car will present more torque and roll out a bit better and pull a bit harder through more of the RPM range than the car without.
Anyways nothings perfect but VVT on a street/strip car is a nice addition but for all out drag racing its not really beneficial as you can just let the stall or the slipper clutch make up for the loss of power down low hence my mention of a manual trans above to make my point. But if I was building an all out drag car I'd be adding boost like crazy and could care less about anything other than peak hp and then work the car out around the engine.
All said and done for street use VVT is a nice thing to have and will add to your smiles per mile. Plus the side benefit that the car will run more efficiently and get better fuel mileage
Im running it on this next build
Just some food for thought.
I use the GMPP intake ($275.00)
I use a Crower Cams camshaft (232/252@118c/l)
I use the "yellow" springs.
DO NOT USE the CompCams "phaser limiter", they allow for FULL advance (108-114) ONLY on a 118 C/L stock camshaft and they seem to "stick" at FULL advance.
The best part of this "bit-of-kit" is that the VVT controller is included as a standard feature of the IGN-8 Ignition System.
Lance
In fact Im going to be taking a VERY close look at the internals of that phaser when I get it open and see if i can find out how/if the Comp kit can get stuck or hung up on anything. Might have to make a part or two new but meh thats custom car bui8lding for ya.
Regardless Lance I'd like to hear about your issues that you had with it mechanically speaking and whether or not your fixed it. Thanks
