LS3 Throttle body options
Having a built 416 with L92 heads and an LS3 intake manifold. Its going in a C5 vette that is DBW. What throttle body options do I have?
Am I limited to these two?
Stock 90mm
NW 102mm
Also will the NW 102mm fit a factory LS3 intake manifold? Thanks!
(I plan on getting the fast down the road.)
Stock 90mm
NW 102mm
Has anyone tried the edelbrock one? It looks cheaper than the others and comes with sensors. I've never had quality issues with anything made by edelbrock.
http://www.jegs.com/i/Edelbrock/350/...0002/-1?CT=999
We need a cable operated 90mm TB for use on an LS3 intake. Was going to try this one.
My main question is if there will be any interference running a 102mm Throttle body on a factory LS3 intake manifold. I do not own a throttle body for an ls3 manifold and I don't want to drop another thousand bucks on my build buying a fast as I already own a factory LS3 manifold. Looks like a 90mm will cost me about 300 and the nw 102 will run me 500. So I'd rather just buy the 102 for 500 if it will fit a factory LS3 manifold. Any other companies building drive by wire 102mm throttle bodies?
Well I just purchased a NW102 MM TB. I'll be bolting it up to the stock LS3 intake manifold as soon as it arrives to see if you need a spacing kit to allow the big bore throttle body on a factory intake.
i just bought my LS3 intake, stock fuel fails, and stock injectors off of a LS3 corvette from ebay for 305 shipped to my door. the company i bought it from is a corvette recycling yard and they said they had like 8 set ups left.
