LS7 Oil Filter Thread Size - Take-off Plate Size
Hi Folks,
This baby is about to roar. It's been a long time coming!!!
One of the last details is to mount a remote oil filter. The chassis cross-member is in the way. The filter is OK when on, but the engine will have to be lifted to remove it and I don't want to do that every time I change the oil.
I don't have the parts yet and am considering the plumbing. Right now, I have the oil pressure sensor in the little cover over the filter. I can relocate that into the filter plumbing and use the threaded holes for the lines.
One way or the other, I will have to put a block-off plate, or take-off plate where the filter is. Does anyone know the right size for the oil-filter threads, or where I can get one of these plates?
Thanks! Video soon...
Found the threads for the filter on the LS7 - 22x1.5mm. Now, does anyone know the size of the threaded fittings under the little cover over the top of the filter?
