Problem with LS3 install...no oil pressure and loud squeaking noise!
I just got done installing a built LS3 in my car, Ive had no luck thats for sure. I got everything in and done. Went to go start the car and after about 5 min I turned the car off to check over things. Started the car back up and no oil pressure!!! It also is making a LOUD squealing noise so I shut it off QUICK. Drain pan...no metal...checked oil pump pick-up tube...everything looked fine. Did my oil pump lock up? I dont know if it would make a noise if it did. Or could my pickup tube be too close to bottom of the pan? I used a ARP washer on the windage tray to clear ARP rod bolts.
