Fast Lsx 102 Or Victor junior Single Plane With 4150TB
Old 10-26-2010, 08:13 PM
casper383's Avatar
Originally Posted by JustAnotherLS2
How are you doing this? LS2 are DBW. I would like to know what your doing to do this because I want to do this as well, but the 4150 I though, was only for non DBW cars.
The F.A.S.T 4barrell is cable operated, uses TPS and IAT sensors, i machined my own TB cable bracket, this will be a drag only setup with a SD tune from G-Force Motorsports. Motor has TFS 235s, 13.5-1 compression, TH-350, will have 4.56 gears, 29xx raceweight. Should be interesting to see how it acts off the line
Old 10-26-2010, 08:29 PM
JustAnotherLS2's Avatar
No IAC?
And I know its cable operated. How did you convert DBW to cable?
Old 10-26-2010, 08:55 PM
casper383's Avatar
No IAC?
My mistake, it has the IAC and TPS sensors. I'm new to SD tuning im not sure what all is going to be turned off or left on, O2's, MAF? Im using a custom harness to run the motor only, and a 01-02 truck computer... there was never a DBW TB on this motor.
Old 10-26-2010, 09:01 PM
Jenson's Avatar
Setting the maf to fail puts the car in SD. Turn the code off so you don't get an ses. Only turn off the O2's if you have a wideband.
Old 10-26-2010, 09:22 PM
casper383's Avatar
Thanks man, I'm going to get HP tuners after the tune is set at G-Force, hopefully they can give me some pointers for track tuning!
Old 10-27-2010, 10:05 AM
LSWNDR's Avatar
Revving to 7600 what valvetrain do you have??
Old 10-27-2010, 11:17 AM
soundengineer's Avatar
I'm rev limiter at 7800 and I shift out at 7500/7600 ish
lightweight valves
Manley Double srpings and titanium retainers and locks.
Old 10-27-2010, 06:53 PM
casper383's Avatar
Comp double springs, titanium retainers/locks, stainless valves, yella terras, will be reving to 7500
Old 10-28-2010, 01:34 PM
LSWNDR's Avatar
Sweet i have everything except the yella terra's an i think without those man i'm not gonna push it... lol i'm pretty sure that the stock Ls3 offset rockers aren't gonna handle that kinda rpms an what lifters you guys running? I bought Ls7's figuring i'd replace them later if needed an what oil pump you prefer?
Old 10-28-2010, 04:31 PM
HNK
HNK's Avatar
lightweight valves
Scott,
how does that power curve look like?
Old 10-28-2010, 09:24 PM
casper383's Avatar
I was going to run the comp lifters but decided on the morel($600 I think), was told that they were better for high rpm without going solid roller. Im sure the LS7 lifters will hold up for a while, i went with the Melling HV part# 10296
Old 10-29-2010, 08:01 PM
  #32
mike c.'s Avatar
I had the vic jr on my 402ci. It pulled to over 7,200 rpm's made power up top but lost alot of tq down low. I didn't go any faster in the 1/4mi and i just went back to a fast intake.
Old 10-31-2010, 02:04 PM
  #33
LSWNDR's Avatar
Right on man thanks for your guys input on this discussion foreal i'm still in a debate on which one to make my car breath harder an make more power... Eventually it's gonna be a turbo or prochargered LME 408...
Old 11-01-2010, 12:22 PM
  #34
1lejohn's Avatar
If you are going the FI route then I would go with the Vic Jr. It will handle the boost with no problems. The torque peak and or loss will be not be a concern with the Jr. You will have to do some cuttting of the cowling to make it work. I wouldn't waste the money on a Fast.
Old 11-01-2010, 12:34 PM
  #35
+1. The Jr does lose some low end grunt, from what I researched. But Ive heard of people blowing the seals/runners on the Fast's from FI/Nitrous. So the Jr would be optimal for boost. For NA, I would hand it to the FAST, IMO.
Old 11-01-2010, 10:57 PM
  #36
litle88's Avatar
subscribing, I just ordered my vic jr and ultra low profile elbow too!
Old 11-03-2010, 12:18 PM
  #37
LSWNDR's Avatar
Right on guys appreciate the info on all ends anything more to add like pics of the set-up would be very nice to see as well.
Quick Reply: Fast Lsx 102 Or Victor junior Single Plane With 4150TB
