wheres the best place to find a stock LS3 intake manifold??
Custm2500's #1 Fan
main things I need with it are manifold, rails, and injectors... I've got aftermarket rails I could use if it didnt have them for some reason...
also, LS3 guys, what size TB are most of you upgrading to?? this is a cable TB build...
The opening is made for a 90mm plus T-body. I'm running the Holly 90. Try SPDC for the manifold and parts that you need. I used Summit fuel rails it took alot of work to make custom hold downs for the rails. Actually my son made them.
Custm2500's #1 Fan
yeah, I've got some Edelbrock rails. Making bracketry isnt a problem. I was wanting either a 92 or 95mm TB with massaging the opening on the manifold so the air entering through the TB isnt interrupted and cause turbulance.
