LS7 FAST 102 running out of steam?
At 6,600 rpm it goes real rich and starts to stumble. We think the FAST 102 intake is choking itself out at that point.
We initially thought it may have been spark related, so we changed plug wires, then coils.
We also originally thought maybe valve float, but the springs have 460 lbs of open pressure.
What do you think?
I have the stock intake duct on my car, wonder if it's holding me back? FWIW I think you might be right.
Christian
What do you think?
Christian
Valve float - or valve bounce - actually doesn't have that much to do with spring pressure. If you have a strong enough harmonic somewhere in the valvetrain - spring harmonics, pushrod flex, etc - you'll get bounce with almost any amount of static spring pressure.
The FAST 102 has been opened up to 107mm and "massaged" heavily by VA Speed - much more than a simple port matching or porting.
I will look up valve size when I get home. I can say that the valves are the hollow stem steel variety from MAST, and the springs are their top of the line.
As far as coil bind, the springs were set-up by the shop that did the heads to match the cam.
