Need Throttle Body Help.
Old Jan 6, 2011 | 06:25 PM
IDRIVEAG8GT's Avatar
Default Need Throttle Body Help.
Hey guys. Have an 07 Silverado with an E38/T42, and originally came with a 6.0 V-Max. Does anyone have an idea what to do on Throttle Body choice? The stock TB is not really big, and is bumpy, and slow to respond. The LS3/LS7's are much faster as I understand and smooth for much improved airflow. If I were to get one (and it works on my Silverado) can they be Powder Coated and ported. I'm doing some custom work and I'd like to be enlightened on this matter.
-Thanks!
Old Jan 10, 2011 | 02:11 PM
And if anybody knows if an LS7 TB will work fine, where can it be sent for the best porting job?
Old Jan 11, 2011 | 08:36 AM
Bad Chad's Avatar
-Thanks!
I have a 90mm off a 2010 Vette that had 650 miles on it I will sell for $200.00 shipped if it will work for you.
Old Jan 12, 2011 | 02:58 PM
riverflyr's Avatar
Can a LS3 throttle body be run upside down to move the mass to the driver side?
Old Jan 13, 2011 | 11:57 AM
67RSCamaroVette's Avatar
Yes.. Ls2/Ls3/Ls7 throttle bodies are the same, and since the bolt pattern is the same on both sides, you can flip it which way you want.. You can score one on fleabay for about $80-100. There isnt much you can do in the way of porting, they are relatively straight-through, and there isnt much material thickness around the edges. You may need an adapter to go from your truck harness to the LS2/3/7 90mm DBW TB.
Old Jan 14, 2011 | 01:57 PM
SNLPerformance's Avatar
In '09 the opening direction of the drive by wire throttle bodies was changed and will not work with the older ones even though the harness is the same, because the tach module signal isn't the same. They can be identified by there gold throttle blade, Chris
Old Jan 14, 2011 | 04:16 PM
95wannabe's Avatar
Anyone try one of these?
Old Jan 16, 2011 | 09:16 PM
riverflyr's Avatar
Wow, Thanks, That's good to know...
Old Jan 19, 2011 | 11:50 AM
Here is a thread that will help you with the connector.
http://www.performancetrucks.net/for...d.php?t=386329
The 2005 corvette pigtail, ACDelco part # PT1760
Good luck.
