AFR 230 V2 - worth the upgrade for my 402?
waddisme and 35th camaro-
what compression are you guys running?
reason i ask is i had the patriots stage III, though they were hand ported some, ported ls6 intake with a 92mm snout, NW 92mm TB, and i put down 507/484 at the wheels, and coolant was flooding cyl 8. i was running 12:1 scr though.
kept reading both of your threads, and thought i share my experience.
i am running 10.6c/r, would have went higher but at the time was going to run a smaller cam that i alredy had 224-224, the patriot heads i have are stage 3 76cc 2.08 - 1.6.
Your DCR might be a little low with that MS3 in there if your only at 11.2:1 I think the ms3 is 237 242 at 113lsa no advance on xer lobes. I'm at 11.83:1 on my 383 with a 238 242 114 on advance, xer lobes and my DCR is 8.41:1. Depending on fuel I'd shoot for 8.4-8.5 dcr as I can run 91 if I want with no problems. Something to think about when setting up the new heads.
I make 530hp 470tq on my 402ci with trick flow 235 heads a non ported fast 102mm on a stang dyno. I also in the past on my ls1 gained 40hp going from budjet ported heads to AFR heads on my car.(i would call patriot a budjet head) I made 463hp on my stock ci ls1. I feel the AFR head will really wake up your car over the patriot head. also,let mammo match you a cam to go with it. You should see over 500hp easy is your motor is in good order.
#32
For those interested here is the results after putting on TF 225s. The AFRs were going to take too long to get. I also upgraded to Kooks 1 7/8 while they had car. First dyno run was when they got car and final was a week later. Good enough for me. Even better is I have all the intake leak and tb issues settled and tune is spot on for dd now. No stumbling, stalling, surging or bucking like a bronco. Drives like a new car. Off to VIR on the 28th so we will see what 50 extra rwhp will do.
[IMG]
[/IMG]
[IMG]
![](http://i10.photobucket.com/albums/a122/waddisme/z06dyno2011Febjpg.jpg)
#35
[IMG]
[/IMG]
[IMG]
Bozz
#36
Closed ex-Sponsor Account
I do believe that there could be an additional 15-25 or so rwhp to be had by upping the compression and a camshaft change, but that was not what was on our plate for this swap.
Zach
#39
Sorry about that
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Zach
