which heads to use on my 427
i can not make up my mind on which heads to use . any help would be great than you.
the details are as follows
ls6 block darton sleeves 4:125 bore
je forged pistons 4:125
callies crank 4"stroke
scat rods 6:125 lentgh
we will be running close to 14:5 to 1 compression and running on e95 special blend fuel.
intake dosn't worry me as i want to tunnel ram it so i will probably have to custom make one anyway.
i was looking at the all pro or the mast motorsport black label heads or even the lsx dr style heads . what do you guys think ?
oh i forgot no cam specs yet i i havn't bought the cam until i get the heads
For the OP I might suggest looking at our new All Pro LSW -2 Race head. We have two programs the larger of which flows over 440cfm. More info can be found here: All Pro LSW -2 Race head. All Pro also has a cast 4bbl intake to fit these new heads. It will be available in cast or CNC finish.
Richard
Stay tuned...........
Richard
You can drop close to 10k on heads if you want but what kind of power are you looking for and how many rpm are you going to run. Lots to consider when looking at heads.
thank you everybody for there help on this topic.
