Holley valve covers.....which coils??
Old Aug 18, 2011 | 08:52 AM
bluehawk2's Avatar
Default Holley valve covers.....which coils??
I was looking at the Holley valve covers and I was wondering if anybody knew what coils they would fit. It says ls3 style with 72mm bolt spacing, but I need to run truck coils for my efi system. Does truck coils have the same bolt spacing as ls3 coils??
http://holley.com/241-91.asp
Has anybody used these valve covers before?
Old Aug 18, 2011 | 09:26 AM
82cetuner's Avatar
there brand new to the market so you probably wont find to many people using them yet.
why do you have to use truck coils? makes no sense to me you should be able to swap them at will, even if the pins are different you can splice the ends of the harness to each coil to accept any type
Old Aug 18, 2011 | 11:03 AM
bluehawk2's Avatar
Im running BS3 and that is the coil they use
Old Aug 20, 2011 | 05:47 PM
Jontall's Avatar
LS2,3,7 are all 72mm.
Old Aug 23, 2011 | 09:16 AM
bluehawk2's Avatar
Thank you!!! Now I just need to know if they will clear my rockers.
Old Aug 23, 2011 | 10:12 AM
Jontall's Avatar
They are super nice and a great price too.
Old Aug 23, 2011 | 10:20 AM
Jontall's Avatar
Old Aug 23, 2011 | 10:56 AM
bluehawk2's Avatar
I will deff give these a try..........My rockers will fit under stock valve cover with the baffles removed, so maybe these will fit with the baffle. It never does say if they offer more clearance than stock.
Old Aug 23, 2011 | 04:28 PM
Jontall's Avatar
Features
Angled coil mounts deliver a smooth clean look
Retain the high-tech look and performance of “coil on cover”
Eliminates unsightly OE style coil brackets
Four finishes available (Natural Cast, Satin, Black Krinkle & Polished)
Billet aluminum oil fill cap
Reuses original gaskets and bolts
Fits all LS engines using LS3 or similar coils with 72mm bolt spacing
Clearance for .750” lift cam with stock style rocker arms
Holley’s LS covers utilize proven OE style baffles and vents.
Old Nov 3, 2011 | 12:46 AM
ShredSled's Avatar
anyone try to mod these to run ls1 or truck style coils yet?
Old Nov 6, 2011 | 05:31 AM
djfury05's Avatar
The LS1 coils and D585 truck coils are not going to work with these covers. The LS1's have slightly less bolt spacing for the holes, and the D585 coils have a completely different mounting pattern which you will need the bracket to come with, and those will not bolt to the Holley's.
Need to find LS2, 3, 7 coils with 72mm bolt spacing.
Old Nov 6, 2011 | 05:52 AM
Undertow74's Avatar
well i ordered a set back when then came out the first week of october, still waiting on them to come in. Holley apparently makes them as the orders come because they dont keep a supply on hand, thats at least what i was told. and i will let you know how i have to mod these to work with LS1 coils. Because when i ordered them i thought they worked with all LS coils, but i misread that one. So on that note, i guess i will find out if i can make them work with LS1 coils!
Old Nov 6, 2011 | 06:06 AM
djfury05's Avatar
If you can elongate the mounting holes about 3.5mm for each the top and bottom hole you might be able get it to fit. Stock LS1 coil bolt spacing is 65.2mm. The ones needed at 72mm. Good luck.
Old Nov 6, 2011 | 08:52 AM
Jimbo1367's Avatar
I seen these before and really like these too.
Originally Posted by Jontall
Old Nov 6, 2011 | 09:55 AM
ShredSled's Avatar
why wouldn't the truck coils mount up, now that I notice in the photo above that they are also 72mm spacing?
...and what would I do with my pcv valve since on my truck it is in the back of the driver's side cover and there is no opening for it on these?
Could I run one of the external ones from the early ls's?
Old Nov 6, 2011 | 10:31 AM
djfury05's Avatar
here's a small picture but gets the point across
Old Nov 6, 2011 | 11:18 AM
ShredSled's Avatar
huh, ok, yeah I forgot about the different mounting style of the d585 truck coils
I'd have to figure out how to modify pcv too?
Old Nov 8, 2011 | 08:55 AM
djfury05's Avatar
Just ordered a set of these in as-cast version so I can powdercoat them gloss black.. also bought some new coils to go with.
Old Nov 8, 2011 | 09:49 AM
ShredSled's Avatar
where did you order them from, if you don't mind me asking... I've been looking at teamc website, at either “as cast“, or satin... Saw a recommend for them on corvetteforum and the prices are very cheap!
But I hear these covers are taking awhile to get out to distributors...?
Please post up photos of yours when you receive them! I'd like to see the underside.
Old Nov 8, 2011 | 10:00 AM
djfury05's Avatar
I just ordered from a site name that rhymes with Kegs with a bunch of other ****. They were $149.99. I don't know how long they take but I'm not really worried about it because I am deployed at the moment for another 3-4 months yet lol.
