Lq4 shortblock+l92s=PTV issues?
Opinions? or is this something that is regularly done
I just put LS3 heads on a LQ4 this summer, check out this thread I had going. I had some PTV issues.
https://ls1tech.com/forums/generatio...close-run.html
Remember that LQ4 has dished pistons so you get a little wiggle room. IDK how many times the stock bottom end with like that high of an RPM but hey it'll be fun to try. If you're gonna take the bottom end apart I hear it's a good bet so get everything balanced. GM does a Meh-so-so job on the balancing so there's some improvement there. Also it would be a good investment at this point for ARP hardware anywhere you can afford.
