full line up of ITBs
Old Sep 19, 2011 | 08:08 PM
2efnfast's Avatar
Originally Posted by Stage7
Haha...not as much room as you would guess! But yes, more options than c5 or c6 Corvette. I'm not running the plenum due to some interference. I have another filter solution lined up. We will see how it works out. I will post filtered and non-filtered results.
-100hp or -200hp due to filtration?
Old Sep 21, 2011 | 09:52 AM
Stage7's Avatar
The kind that will fit in the car w/out mods, and comes off in 5 seconds if there is a drop with them on when I need more power.
Old Sep 22, 2011 | 08:07 AM
bug man nrg's Avatar
Originally Posted by Schitzo
Jenvey on my BMW LS1
are there more pics of this set up ???
If so come on let us see them
Old Sep 24, 2011 | 12:58 AM
Schitzo's Avatar
Not really.That was just a test fit while I had my regular intake off. The Jenvey intake is a side project I have been working on for a while now.
Old Sep 24, 2011 | 09:10 AM
if you find time can you install it and post pics. PM me
Old Sep 27, 2011 | 11:39 PM
topfuelman's Avatar
Default ITB's under the cowl of an e36 BMW
Man I've had a set of ITB's up and running in this e36 chassis for 5 years. First on an ls1 now on an ls2. As for tuning...you just need a good tuner! Of course my set-up which originated in Australia does have a common plenum area...albeit not a large volume. I had to build left and right side plenums which are fed by a common airbox tucked above the rad and behind the kidney grill. It acts as ram air at speed.
You can set the idle at practically any rpm you would like. The ITB's do tame cams big time!
With the 50mm ITB's, My stock ls2 with a cam and good pushrods, roller rockers, headers makes 427 RWHP on a load type dyno (Mustang). So I am not sure if they make huge power, but they seem to keep a nice flat torque curve...at least in my application with limited volume plenums.
Spraying Nitrous I did manage to get the car over 300 KPH at a Top Speed event up here in Canada. The event is running again in 2012, where I am tempted to replace the old T56 with a Magnum for a little better top speed (less underdriven 6th gear)
Attached Thumbnails full line up of ITBs-ls1_e36.jpg   full line up of ITBs-picture-4.png
Old Sep 28, 2011 | 07:45 AM
1CAMWNDR's Avatar
ITBs are just awesome....
Old Sep 28, 2011 | 09:32 PM
I like the look of that set up what brand are they ???
Old Sep 29, 2011 | 01:07 PM
2efnfast's Avatar
Random stranger: "Wana race for pinks?"
Roberto: "Sure, just a sec" ...... opens both doors, lowers diffuser, opens rear clip, removes air filters, closes rear clip, raises diffuser, closes both doors...."okay, let's race ... hey, where'd you go?"
Old Sep 29, 2011 | 02:45 PM
RAMPANT's Avatar
My Harrop never made what I had hoped for, but it lost nothing with the plenum and filter in place, in fact it gained about 5hp when we installed it, though it was after a cool down. So I am not 100% on the gain. It also fit under a stock WS6 hood with very little mods. The Ram Air will not hurt either.
The tubing and elbows are 4".
Old Oct 5, 2011 | 09:13 PM
that is a nice air box did that come with the kit
Old Oct 5, 2011 | 09:20 PM
  #32
RAMPANT's Avatar
No, I bought it used from a guy who had a weird, poor functioning cowl set up. I cut them up and spent 30 hours modifying them to what you see. They seem work pretty good.
This is how it looked before the mods. It looked really nice, but was extremely restrictive.
Old Oct 6, 2011 | 10:00 PM
  #33
that looks alright why did you find the need to do mods to it ???
Old Oct 7, 2011 | 06:01 AM
  #34
RAMPANT's Avatar
One his was specific to a GTO. He also noted 25rwhp loss with it installed.
So I thought the Ram Air connection and a clean air flow into the boxes would help remove the restrictions, if not prove a gain at speed.
His openings and air path were poor. sharp turns and long narrow openings. Mine is almost as smooth as you can get, with 4" piping doing the feeding.
Old Oct 7, 2011 | 07:10 AM
  #35
LPE 403's Avatar
Dont think I will have the same fortune with my Kinsler set up. At almost 9" it may require a cowl tweak or K-shim. Any idea how tall your Harrop is?
Cool factor alone should be worth the effort
Old Oct 7, 2011 | 07:57 PM
  #36
RAMPANT's Avatar
Where did you measure from, the top of the valley cover?
I can get you that measurement.
Old Oct 8, 2011 | 07:23 AM
  #37
LPE 403's Avatar
Yep...thanks!
Old Oct 11, 2011 | 10:19 AM
  #38
RAMPANT's Avatar
Finally measured it.
It is 7.5" from the top of the stock valley cover to the top of my plenums flange. All I modified was under the windshield there is metal that encloses the wiper mechanism. On the drivers side it hangs a little lower, I massaged that upwards about 1/4" and it still cleared the linkages.
Old Oct 11, 2011 | 12:33 PM
  #39
2efnfast's Avatar
How much did that setup cost? (i've heard 15-20k for carb Kinsler stuff, so I'm really curious)
Old Oct 11, 2011 | 08:39 PM
  #40
LPE 403's Avatar
Thanks for confirming my fears!
PM sent....
