402 LS2 with TFS as cast 220 and YT Valve Cover clearance issues?
Before I fire up my new mill, does anyone have a definitive answer on whether my factory ls2 covers will have enough clerance for the YT 1.7 rockers and TFS as cast 220 heads? Searching has gotten me a variety of answers.
Thanks!
Thanks!
Im not sure about the YT rockers but my Harlands are pretty shout in size and shape and Iv had no problems. You could install a cover but not run the bolts all the way down so that the cover can move up a bit if one does contact. Use a pull handle or a rachet and spin the motor over by hand and see if contact is made, if not button it up, prime you oiling system and fire it up!
