Direct Injection What's on your mind??
Old Apr 13, 2012 | 09:01 PM
ramairws6's Avatar
Default Direct Injection What's on your mind??
GM stated that the new Gen V engines will come out with Direct Injection. Sounds like pretty good technology that has been around for a little while. I'm wondering what if any it will carry over into the performance market for high HP builds. Sure sounds promising. What is everyone's thoughts?
Old Apr 14, 2012 | 07:37 PM
ramairws6's Avatar
732 veiws and nobody has any thoughts or input on this? Wow, slow days on Tech...
Old Apr 15, 2012 | 10:32 AM
brngrhd's Avatar
as long as the fuel system is up to the task it will be fine.
Old Apr 15, 2012 | 02:04 PM
Old Geezer's Avatar
Operating psi is to the moon....75 to 200 bar. AFR's in the econo mode at 65:1, performance range at 25:1. Op volts as hi as 90.
Old Apr 15, 2012 | 02:24 PM
ramairws6's Avatar
So with all this will we be benefiting at all?
Old Apr 15, 2012 | 05:04 PM
kyoytey1693's Avatar
We'll have to benefit from it. Once everyone realizes the benefits, you won't want anything else. This isn't a new technology by any means. Diesels have been this way almost forever. This is how they run such high combustion #'s, dont require spark plugs, and can burn a fuel that is less refined.
I honestly dont know why we haven't implemented this into the gasoline world long ago. I'm excited about it. I look for the OEM's to come out with some crate engines that offer DI, similar to what GM has done with the E-rod's. Once that happens I expect the aftermarket to be all over it. It will require some revamping of our factory fuel systems but it will be worth it.
Old Apr 17, 2012 | 08:00 AM
ramairws6's Avatar
I agree 100%. If it takes a little extra money to gain me a little more HP, drivability, and maybe even a little more MPG i'm all for it
Old Apr 17, 2012 | 09:31 AM
t/a98's Avatar
I went from gen 3 motor to a gen 4. Better believe I'll be all over gen 5.
Old Apr 17, 2012 | 09:37 AM
Z28Z06's Avatar
If I recall correctly the Cadillac V6 picked up 50 horsepower a couple of years ago when they went to direct injection. I am surprised that direct injection has not been engineered into the GM performance V8s yet.
Old Apr 17, 2012 | 09:58 AM
ramairws6's Avatar
I agree. I hope it's something we can retrofit to our Fast intake or it will be more $$ right out the window again!
Old Apr 17, 2012 | 10:10 AM
bww3588's Avatar
I hope your kidding...DI requires a different cylinder head design with a boss for the fuel injector as well as the spark plug. Fuel is sprayed....directly....into the cylinder.
Old Apr 17, 2012 | 11:50 AM
redtan's Avatar
Yeah, you're going to need a completely new top end from cylinder heads to intake manifold. The whole point of DI is that the injector sits in the head and not in the intake track anymore...so retrofitting DI to current engines will have nothing to do with the intake manifold. At the least it would be plugging up the existing injector holes as they will be of no use anymore and you don't want open holes in your manifold.
Old Apr 17, 2012 | 12:05 PM
ramairws6's Avatar
Hahahaha, man we needa sarcasm/joke button in this place
Old Apr 17, 2012 | 12:50 PM
redtan's Avatar
With all the dumb people/posts in this forum, one can never be to careful with seemingly idiotic posts. It's better to be safe than sorry, so when I am faced with such posts I tend to just go along as if the post was real and not sarcastic.
Old Apr 17, 2012 | 12:53 PM
ramairws6's Avatar
Oh i understand, guy never knows his/her machanical knowledge from behind the keybord. I assure you it's not the case here
Old Apr 17, 2012 | 01:00 PM
I have been looking for a sarcasm font for years!
Old Apr 20, 2012 | 06:26 AM
427 zeo6's Avatar
Direct injection brings a bunch of problems to the table. Go check out the Audi RS4 forums for the power robbing valve debris build up that happens because there is no cleaning fuel wash across the back of the intake valve head. This is now happening to the GM V6 motors, VW DI motors, Lexus DI motors and many others.
Old Apr 20, 2012 | 07:10 AM
G8-4-speed's Avatar
As a minimum, your going to have to swap over to a vented catch can and not run any vaccum or vent to the intake from the crank case. The maybe add a methanol injection or water/meth and retune it so you can keep it clean inside.
Old Apr 20, 2012 | 07:20 AM
ramairws6's Avatar
Issues reeling their ugly heads that soon in the game means it will be quite sometime for it is perfected
Old Apr 20, 2012 | 12:56 PM
redtan's Avatar
If you've every seen valves in most port injection engines you'd know that no valve is ever spotless. Fuel can be dirty too, and it can gum up on the valve just as much as oil.
As mentioned, a simple solution would be for a catch can to be installed or the PCV system to be vented out in the air as apposed to pulled by the vacuum back in the manifold.
