"UPDATE"!Well, well, WTF Happened Here!??
Old 06-04-2012, 09:08 PM
  #101
ramairws6's Avatar
No, no pinched wires. Tune is back to where it was but still comes up with the P0300 missfire code. The thing is not missing a beat so i am temted just to take this code out in the tune. Starter seems to be working good again 'knock on wood' Only time will tell i guess
Old 06-04-2012, 10:46 PM
  #102
DrkPhx's Avatar
If the code is deleted and comes back (not good), check the freeze frame data which will show the exact conditions the code is tripped.
Old 06-05-2012, 08:54 PM
  #103
ramairws6's Avatar
I never did delete the P0300 code. I just assumed since i never had this code before Andy had just desensitized or dumbed it down and left it on. Isn't this what a good tunner usually does so you still could use it for a missfire? I haven't checked if it's off yet but i had some weird crap like this show up lately. The P0141 and P0161 code started popping on and the MIL status has been checked as off but wasn't done in a different spot in the tune. Looks like there are 2 different spots that need to be turned off, not??
Old 06-06-2012, 08:31 PM
  #104
ramairws6's Avatar
Checked all freeze frame data. It's been tripping it at or around the 1200-1500 rpm range i guess. Once in open loop and once in closed loop status. In the engine and diagnostic under setting mil it states that the code is set to go 2 trips and emmisions related. Both areas this code is still checked in the tune. Thing that is weird is that it has never tripped this code before all these starter issues? Took it out and it is not missfiring a beat under throttle at anytime.
Old 06-07-2012, 09:21 AM
  #105
Danny's Avatar
A buddy of mine had his block replaced years ago due to this very reason. His car is a 2000 and stock down to the paper filter. His starter ripped right off and took a piece of the block with it. The dealer swapped out the entire long block because of this. He's had his new long block for years now and no problems. Maybe it was a hand full of defective blocks. Maybe bubbles in the casting in that area
Old 06-07-2012, 06:18 PM
  #106
ramairws6's Avatar
Hahahaha, thanks for the advice but this thing is so far from stock it's not even funny!
Old 06-07-2012, 06:51 PM
  #107
DrkPhx's Avatar
I agree. It's common to set this code with a big cam at idle, BUT if it was never set before and the tune is the same, there could be reason for concern. Check the crankshaft position sensor since it's located right next to the starter. The starter could have bumped it when it broke. I would also check the valve springs, pushrods, etc.
Old 06-07-2012, 08:14 PM
  #108
ramairws6's Avatar
Never even thought of the crank sensor being damaged from the starters breaking! Hey good call man!! I did have a crank sensor A malfunction code a few times awhile back too but that went away. I bet money that's the solution. Damn i will be happy if it's just that
Old 06-10-2012, 07:55 PM
  #109
NHRA4MULA's Avatar
How did you make out is it all good now ???
Old 06-10-2012, 08:03 PM
  #110
ramairws6's Avatar
Will know tomorrow. Had a busy weekend. The airshow and Blue Angels were in town (my wife is a pilot) so we couldn't miss that of course!
Old 06-16-2012, 08:54 PM
  #111
CharlieB53's Avatar
The combination of compression and initial timing can be tough on starters.
If you have the ability to retard cranking timing, say all RPM more than 100 less than your normal idle RPM, that should reduce starter load and extend life.
My BBC, back in the day, had a ign kill switch I'd use till cranking speed was up, then armed the ign, never killed another starter.
Old 06-18-2012, 05:27 PM
  #112
ramairws6's Avatar
New crank sensor and it still pops the code so i just went in and tuned it out. Not sure why i have the code showing up all of a sudden but the starter issue has been so far so good!?
Old 06-26-2012, 12:21 PM
  #113
ramairws6's Avatar
Ok, so i finally think i have this issue figured out. I replaced the crank sensor without bothering to check the harness because of it being wrapped in electrical tape on top of the corrogated plastic it was running through. I pulled the tape off and the plastic was totally melted and my wires were melted ever so lightly together underneath. Hope this was it. I will replace 18 inches of it with a new plug and weather connectors and see how it goes!? Last ditch effort....
Quick Reply: "UPDATE"!Well, well, WTF Happened Here!??
