Crankcase Evacuation System....
you may find that is quite restrictive, and i doubt you will see flow sufficient to do a good job of crank evac.
pulling from each valve cover would be unrestricted flow to each header, unfortunately much more oil will also come with it (unless you use a catch can)
i think the whole dipstick modding is a waste of time and effort to do or even discuss. it has an o-ring on it, will be just fine not that it would contribute to any measurable leak in the first place.
if you are to use any muffler at all i would not bother with the header evac kits, as they barely work in the first place.
*edit* i forgot to add another note while on my header evac soap box. your rear tires (and all the guys racing after you) will not appreciate oil being sucked out of the engine and being blown down onto them. please consider
They'll add whatever size bulkhead you want.
it fits perfect, its already been tested on several cars...otherwise Bob wouldnt sell it.. and I know Bob personally... Just bought him lunch the other day.
I use the LS1 version, plus some custom baffles and I use a Moroso Vacuum pump setup as well....and a custom mounting bracket from Bob at aeicnc.com
he makes several different brackets to mount the Moroso Vacuum pumps
it is also required that you buy an ATI crank Damper with a special hub that is made to use with the Moroso Pump...
it will cost you quite a bit more than the $100 Header Evac system...but it will also be guaranteed to work 10x better than the header evac system as well.
If you contact bob, he can tell you specific details about what you need for a complete system and he can get you prices..
basically...
Moroso Pump and Bracket
ATI Damper with Hub
Catch Can
Valley Cover
custom baffles or a really good oil/air separator
some fittings and Hose (12an)
Belt for Pump
Pressure relief valve
a little bit of patience and time.
and a way to measure how much vacuum you are actually making (make too much and you suck the oil right off the wrist pins of the pistons and damage your engine...)
