L76 and LS2...same block??
Old Jul 13, 2013 | 08:27 AM
Freefallin's Avatar
Default L76 and LS2...same block??
Quick question...Is the block of the l76 the exact same as the block of a ls2??
Did a search and got a few vague results which say same. Just wanted to make sure before buying one. Also...can i swap the ls1 engine for a l76 on my 04 GTO?? Is it no hassle straight swap plug and play?? Thanks in advance guys!
Old Jul 14, 2013 | 07:51 PM
HSV-GTS-300's Avatar
Yes L76 and LS2 blocks have the same casting number.
No an L76 into a 2004-2006 GTO is not a straight swap.
L76 use 58x crank reluctor & 4x cam reluctor.
All GTO's are set up for 24x and 1x timing reluctors.
Oilpans and front accessories are also different between L76 and GTO.
