LS3 needs a lot of cranking
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I am really stumped and hope someone can give me some ideas.
I have a new GM LS3 430HP in my 55 Chevy and the car runs great. The car starts instantly when cold or sitting overnight. When I drive the car for a while and shut it off for 5 - 30 minutes I have to crank the car over about 10-12 times before it starts.
Any ideas what to look for?
Thanks.
Lorne
Thanks.
Lorne
A code reader if you went computer, check the jetting if you went carb'd. I'd check to make sure that the ignition coils are not getting too hot, check to see if you get a spark while it's still warm.
I have a modified factory harness and computer but I am not getting a code for the extended cranking.
I never considered the coils getting hot. I will check them out.
Thanks
Thanks
LS1Tech Premium Sponsor
I would check the cam sensor as well as make sure the right cam gear is on to match the computer you are trying to use. It is common for cars to be hard to crank when having cam sensor issue but they will run just fine once cranked. Worth checking at least.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
LS1Tech Sponsor
Thanks.
Lorne
Thanks.
Lorne
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic250868_1.gif)
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
www.pcmofnc.com
704-307-4227
