ECU etc for LSx454
ECU etc for LSx454
Hello, I am running an LSx454 with fuel injection, cable throttle and electronic auto.
Is the GM performance LSx454 Engine Controller Kit, part number 19299840 what i need to control the engine?
http://www.jegs.com/i/Chevrolet-Perf...99840/10002/-1
thank in advance
thank in advance
LS1Tech Sponsor
Received 1,121 Likes
VRSenator065,
Due to the fact you will be using the cable operated throttle body the GM Performance 19299840 conrtoller kit will not work for your application.
Holley offers a Dominator EFI system that would work for you. It will control both the engine and GM electronic transmission. For a complete system to get you up and running you will need the following items:
Holley Dominator EFI ECU
Holley Dominator EFI Main Power Harness
Holley Dominator EFI Main Engine Harness 58X
Holley Dominator EFI Transmission Harness
Oxygen Sensor
Map Sensor
Coolant Sensor
Air temp sensor
And one of the following depending on injector style:
Holley Dominator EFI Injector Harness Bosch
Holley Dominator EFI Injector Harness EV6
Oxygen Sensor
Map Sensor
Coolant Sensor
Air temp sensor
thank in advance
thank in advance
