4500 tb
Old Jan 10, 2014 | 05:08 PM
Bill71's Avatar
Default 4500 tb
I am looking for a monoblade throttle body. I have seen them with a 4150 base but Mast said I should use a 4500 base for their 2 piece intake in a 427. Do not want to use a spacer/adapter since it will probably cause hood clearance problems.
Old Jan 10, 2014 | 07:54 PM
S10xGN's Avatar
Ron's doesn't say, but you could call them...
Old Jan 10, 2014 | 08:26 PM
Bill71's Avatar
I've seen that one. It appeas to be very tall but I should call them for info.
Old Jan 11, 2014 | 03:41 AM
Gray86hatch's Avatar
Why not just use a 4500 style
Tim
Old Feb 18, 2014 | 09:58 AM
Bill71's Avatar
Tim
I wanted more linear throttle control. My experience with a Holley DP was that it was hard to apply throttle once I got into the secondaries. Tires would spin.
Old Feb 18, 2014 | 10:52 AM
Never been able to feel the second 1/2 of the tb open on mine. It is not a carb. Should be a smooth seamless transition
Tim
Old Feb 18, 2014 | 12:29 PM
COSPEED2's Avatar
LS1Tech Sponsor
Scorpion has a rather nice TB that flows quite a bit and it is a low profile design. 2000 CFM out of a 4150 flange is not a slouch. They are not monoblade, but they are rather easy to tune as far as the higher flowing TBs go.
Old Apr 6, 2014 | 01:16 PM
John B's Avatar
Moderator
My experience putting a single large monoblade 102mm TB on my LSX intake was a bust when it came to low speed drivability!
