A Billet $98 92mm Cable 4 bolt TB ! What ????
Old 02-27-2014 | 08:24 PM
LT1PWRD's Avatar
Default A Billet $98 92mm Cable 4 bolt TB ! What ????
Yep,you read that right folks... Just got it today,actually looks pretty well made(copied). Is it chinese? yup.. Does it suck that i baught a chinese knock off to get this price? yup... Will it work or last? most likeley,ill find out when it's on my LS2 intake and eventually subjeted to boost. If it does work/last i saved $400 cuz it doesn't say Nick Williams or FAST on it.
Here's a few pics...
Attached Thumbnails A Billet  92mm Cable 4 bolt TB ! What ????-tb1.jpg   A Billet  92mm Cable 4 bolt TB ! What ????-tb2.jpg   A Billet  92mm Cable 4 bolt TB ! What ????-tb3.jpg   A Billet  92mm Cable 4 bolt TB ! What ????-tb4.jpg
Old 02-27-2014 | 08:57 PM
Kory 88Iroc Lt1's Avatar
Ebay? got a link? It looks good.
Kory
Old 02-27-2014 | 09:04 PM
LT1PWRD's Avatar
Yup,sure do. It's the only US seller i found on Ebay at this price. Also have a 102 available as well.
http://www.ebay.com/itm/POLISH-92MM-GM-GEN-III-LS1-LS2-LS6-THROTTLE-BODY-LS3-LS-LS7-SX-LS-4-BOLT-CABLE-/271412705170?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3f31753792
http://www.ebay.com/itm/POLISH-102MM-GM-GEN-III-LS1-LS2-LS6-THROTTLE-BODY-LS3-LS-LS7-SX-LS-4-BOLT-CABLE-/291090054971?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43c651bf3b
Old 02-27-2014 | 10:00 PM
schmendog's Avatar
I had one, they are poorly made. return it if you can my friend
If you decide to keep it, here's what I had to do to mine:
-Remove the screws that mount the throttle blade and apply Loctite (mine backed out)
-Be prepared to have to sand the edges of the throttle blade because mine was too big, and kept getting stuck
-IAC mounting holes in wrong location so I had to bring to a machine shop to tap new holes.
-Disassemble cam and remove spring and trim it down, it has WAY to much spring pressure
Old 02-27-2014 | 10:12 PM
To save 400 bucks I'd be willing to do those modifications.
jmo.
Kory
Old 02-27-2014 | 11:51 PM
MUSTANGBRKR02's Avatar
It will rust and the throttle blade won't open.
Old 02-28-2014 | 07:10 AM
Wow ,I Wouldn't Have Thought Of That. Isn't The Throttle Body Machines Out Of Aluminum? Thanks For The Info.
Old 02-28-2014 | 10:35 AM
LT1PWRD's Avatar
Thanks for the advice. That was one of my first thaughts on the throttle blade screws as well,not takin a chance on that! I'll try to work out any issues that may arise,if any.
I have more patience and skills than money.....
I don't have an iac or tps yet so i dunno on fitment yet.
Old 02-28-2014 | 12:43 PM
ls1_chevelle's Avatar
No its typically stainless or a coated mild steel. Aluminum couldn't survive.
Old 02-28-2014 | 01:14 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I had one, and it was a nightmare. Couldn't get the car tuned or drivable at all, and this is when I was NA. Either the blade would stick open, or the IAC would stick, or I had air gaps and the IAC closed completely. I had all three problems at different times till I said F'it and tossed it.
Old 02-28-2014 | 02:45 PM
speer13's Avatar
Also for boosted applications they usually do not hold up to much pressure before leaking by the shaft and other areas do to tolerance, shotty seals etc. but if you have no money (or don't want to spend it) and want to spend time on it go for it.....
Old 02-28-2014 | 05:08 PM
thunderstruck507's Avatar
I am finally giving up on my Fast 90mm tb and ordered a Ballistic Speed unit today. They are priced reasonable and look to be good quality. The couple members here who have bought them say they are great.
Once I get it installed expect a full write up and review in the Gen 3 external section. Can't be any worse than my Fast 90mm. So far I have had to clearance the blade to open/close and port the IAC chamber to try to get it to idle, it's "better" but still troublesome as far as idle goes. Tune has been worked and worked and worked both for airflow, fuel, and timing.
http://ballisticspeedparts.com/shop/...y-for-ls2-ls3/
Old 02-28-2014 | 05:48 PM
LS1MCSS's Avatar
The body is what he is talking about and it is aluminum.
Old 03-17-2014 | 12:35 PM
Just a follow up, I got the Ballistic Speed tb installed and it works great, drives great, and doesn't break the bank.
Review is posted in Gen III external. I definitely recommend them if someone doesn't want the hassle of the ebay knock offs.
If the price is still too high keep a watch as I've seen them go on sale before. I think back on black friday they were under $200 shipped.
Quick Reply: A Billet $98 92mm Cable 4 bolt TB ! What ????
