Is an LS6 water pump interchangeable with an LS3 water pump? (need wider pulley)
Old 03-07-2014 | 10:36 AM
turbotuner20v's Avatar
Default Is an LS6 water pump interchangeable with an LS3 water pump? (need wider pulley)
I'm running a built 4th gen iron block w/ LSA heads and my original '09+ LS3 water pump in my vette and am looking for wider water pump pulley options to accomodate my blower belt.
Here's a comparison of the LS1 pump/pulley vs. LS3 pump/pulley. I don't think the LS1 is a direct swap, but I've heard the LS6 might work? Any thoughts on how to get a wider pulley?
Here's an LS6 pump on an LS7
Old 03-07-2014 | 08:26 PM
S10xGN's Avatar
I've got the pump on the bottom, if you have the top one, I'd be happy to trade.
Old 05-20-2014 | 12:28 PM
White Out's Avatar
LS3 will work with Corvette accessories
LS3 will work with F-body accessories with 3/4" water pump spacers
Old 05-25-2014 | 08:18 AM
stevieturbo's Avatar
LS3 will also work on F-Body if you pull the pulley off the pump shaft by approx 8mm.
Leaves you a lot more clearance up front.
Quick Reply: Is an LS6 water pump interchangeable with an LS3 water pump? (need wider pulley)
