Anyone modify a Kooks TD?
The Magnaflows that are that size seem to do a good job... but those Kooks are 304SS like the rest of the system. Magnaflow is 409. Meh.
2) If you want to run high flow cats with the hopes of passing inspection - Yes of course.
If #1, then:
Vibrant Performance Resonators (The best volume reducers) I'd say you're about 30% less volume by adding just one. They mean business.
If #2, then:
Yes. Add the high flows.
Trying to understand your situation.
Are you trying to reduce volume? If so, what I'm saying is - the bottle style Resonators from Vibrant are simply your *best* bet. You'd have to cut out a piece of your exhaust, and weld the resonators in. If you are limited on space and only have space to weld one in, it is well-worth the effort.
Don't remove your current muffler or whatever you're using, just add the resonator in the piping some where. Cut and replace regular piping with the resonator.
But yes, I am trying to reduce the noise. here are some photos if it helps
*KEEP* your current muffler. Just add the resonator(s) where you can:
Let me know if this makes sense:
You can literally cut out any of those areas marked in red, and weld in the resonators. Find piping straight for 12" or so where you can weld in resonators. They sell 12" versions and 18" versions. 12" are easier to fit. Also, you can make them 10" if you are willing to cut the leaders on both ends a bit.
Any questions? Make sure you are looking at the bottle style 12" Resonators, 3" OD/ID (or whatever your diameter is) - the reason I recommend Vibrant is because for the price they ask, you simply can't beat their quality, and the amount of volume they reduce. I am currently running one on my 427. Helps with drone, but really eliminates volume and cleans up the sound.
Edit:
And no, they don't really affect flow, there will be no difference in power that you could possibly feel by welding some in.
You only need 1 to make a difference. 1 & 4 are your best bet for straight piping.
2 and 3 - only space to weld one side, won't accommodate two side by side.
The rear one will be your *easiest* - but will have a lesser affect. Remember, the closer your can get the resonators to the engine, the more affect they'll have. However, the rear location will still be noticeable. But if you can squeeze one in on the passenger side red circle, one should do the trick. I actually have mine welded in to the rear (bottom picture red circle) and it made a difference.. well, just enough for me to be less annoyed by my own exhaust.
And remember, you want to cut these as square as possible (square as in flush) - a grinding wheel to flatten/re-flush your cuts can help you get a better weld.
It's not easy to do at home unless you're used to working with stuff like this, but take your time and it's well worth the effort.
Another tip:
Don't go hacking away at stuff without first "test fitting" them some where with your eye sight. Make sure there is space available in terms of width, not just length.
I was told by one of their techs that if I threw just a random set of Corsa Mufflers on it would drone; with what he recommended, I have no drone and a completely unique sound.
Ground clearance in the back, under the trunk area, is not very good but acceptable for me to drive daily.
It's the 3" system for the Z06... I figure that would work. I could even try to keep the tips, lol.
Back to trying to figure out how to quiet mine down with the new motor going in...
BUT I got tired of how little the ground clearance was so I swapped them for Kooks KO300-12 mufflers.
The Kooks are not too loud at all; they have a deep, bass sound reminiscent of an old school big block.
Really satisfied.
Only issue is the Dynomax Ultraflos I tried have around 297 in^3 of volume (removing the 3" pipe's volume through the center) and the Kooks 4x8s have 300 in^3 volume of packing. I don't know if it would be much quieter. The UltraFlos are definitely deeper. But still very loud.
