Anyone modify a Kooks TD?
Old Apr 30, 2017 | 02:41 PM
  #101
silplu83's Avatar
I have the catted Kooks TD and I think its too loud. It sounds great at the top end but I would like less noise when I push in the clutch. I am eager to hear results from other mufflers, I like the sound of the Magnaflow and may end up with those.
Old Apr 30, 2017 | 03:10 PM
  #102
JakeFusion's Avatar
Super Hulk Smash
Imagine a stalled auto... with no cats. It just hangs you know at 2500-3000 RPM cruising in traffic until I hit lockup at 40.
Old May 1, 2017 | 12:16 PM
  #103
NitrOmm's Avatar
You know ............. I must say Kooks is a great company, their products are well constructed & performance is top shelf.
But .........
- after more than a few people having the same issue with the Fbody item.
- having $3K + out of pocket for a full system.
MAYBE it would be prudent that Kooks stepped in an at least try to help find a solution. We are not asking for miracles .... just another option that fits.
Old May 1, 2017 | 11:22 PM
  #104
JakeFusion's Avatar
Super Hulk Smash
I don't think they care. It's hard to fit mufflers on the car in this configuration. I know their prototype used two sets of bullets. That might work.
Friend of mine went from the Kooks Bullets to the Kooks Oval mufflers and he said it was night and day on the GTO. Similar story on the CTSV. So if they had offered it with the Oval Mufflers, I think we'd all be happier. They are a little smaller than the Magnaflows as well. But they give it tone and reduce the noise a bit and the interior resonance a lot. But they are still wicked loud.
I also looked more into the Spintechs. Apparently they do cost a lot of HP. So I don't know if that's a good idea or not. Of course, being so far from the engine and having two 3" tubes, I don't know if the Spintechs would cost as much power in this configuration. They would fit a hell of a lot better than anything else.
But I hate to hack up such an expensive system.
Old May 2, 2017 | 12:34 AM
  #105
pdxmotorhead's Avatar
I've used spin-techs on sprint cars, one of the few mufflers we tried that could handle the revs, take the beating and the heat from the methanol burning in them, and would get us under 100DB some of the tracks require. They scream a bit up top (9800 RPM) but what wouldn't.. ? The intake noise is as loud as the exhaust from a distance..
I have one on my Jeep, I'm about to replace it has about 75k on it, my 4cyl is relatively beefed up Head/Cam/springs/pistons etc.. (Yea I know don't laugh too hard..) , Mine is finally splitting a seam, but my engine has issues with the factory ECU being unhappy when it comes off power and it pops pretty hard sometimes (Occasional earth shattering Kaboom) .. Its a 20" long with 2.5 inch pipe. Doesn't drone so much as just build sound as the rpms climb, cruising at 60 is fine at 70 its a lot of throat to it.. I have a random tech cat as well .. going from the stock cat and muffler to the random tech & spintech was a 2x increase in volume at least... Of course a Wrangler is a big echoing boom tube on its own,,, so not the best comparison..
Old May 15, 2017 | 05:07 PM
  #106
maroonls1z's Avatar
Well i put the magnaflows on replacing my hushpowers and honestly to me i cant reall tell a difference. Cold start might actually be a little louder
Old May 27, 2017 | 12:21 PM
  #107
maroonls1z's Avatar
I picked up a pair of spiral flows and im going to add them in like resonators and i bet that will quiet my **** down to what i want. Ill get a video before and after
Old May 27, 2017 | 04:57 PM
  #108
silplu83's Avatar
Awesome can't wait to hear it, I'm looking for a way to quiet mine down.
Old May 28, 2017 | 10:39 PM
  #109
JakeFusion's Avatar
Super Hulk Smash
That sounds like a good idea. The Spiral Flows will fit where the cats would go ahead of the x-pipe.
Old Jun 2, 2017 | 05:53 AM
  #110
maroonls1z's Avatar
im going to put them in the area right before the arch to go over the axel. I heard the headeds need a little room after the collectors to scavenge properly or something.
Old Jun 4, 2017 | 11:44 PM
  #111
JakeFusion's Avatar
Super Hulk Smash
That's a good spot. The Spiralflows flow 650cfm. David Vizard tells us through his testing that 2.2cfm per HP = no loss of power. So 1300cfm = 590HP with no loss. Not terrible.
3" of pipe is good for about 750cfm with no loss. So they are good mufflers.
Old Jun 5, 2017 | 12:02 AM
  #112
JakeFusion's Avatar
Super Hulk Smash
That got me to thinking about muffler cfm.
Hooker Maxflows flow as close to an open pipe as bullets do... but much quieter. Some old *** comparison had them at 80db idle, 90 db cruise, and 120db WOT. Pretty much louder than everything else WOT but quieter everywhere else, while making more power. I don't know if they will fit.
They sound deep as hell in this video:
Old Jun 5, 2017 | 06:01 AM
  #113
maroonls1z's Avatar
I read the 3" flow 850cfm? So that supports 775hp. I have more than 590 so i hope so
Old Jun 5, 2017 | 03:55 PM
  #114
drain89's Avatar
I just picked up a set of the Kooks Green Cats from Maryland Speed during their Labor Day sale. I'm gonna add them in mine when I install it. I've got a SNS Stage 3 (16* overlap IIRC) and M6 so we'll see. If it's still too loud I may swap out the bullets to their KO300-12 Ovals. Or can you think of a better option since I'm using the cats?
Old Jun 5, 2017 | 04:07 PM
  #115
drain89's Avatar
I'm also considering these:
http://vibrantperformance.com/catalo...products_id=47
Old Jun 5, 2017 | 04:57 PM
  #116
JakeFusion's Avatar
Super Hulk Smash
Those Vibrant Resonators I've looked at too. They are just smaller versions of a Magnaflow, Borla, Kooks Oval, or Hooker/Dynomax glass-pack style muffler.
Any of them would work. The Magnaflow and Borla fit where the bullets go. But they are louder than some of the others since they are smaller (but still much quieter than the bullets). The more material you pack into the muffler, the more sound they absorb. One reason I've looked at the Hooker VR304/Maxflow and Dynomax UltraFlo is the cost and the fact that they seem to flow just as well or better. But they are just straight through mufflers with packing material.
Old Jun 12, 2017 | 01:03 AM
  #117
JakeFusion's Avatar
Super Hulk Smash
I just ordered these... hope they fit.
http://www.dynomax.com/mufflers/ultr...tered-556.html
Old Jun 13, 2017 | 04:55 PM
  #118
JakeFusion's Avatar
Super Hulk Smash
Well, if it stops raining this week, I'll drive cross town and get these installed in the bullet location. And if it needs more, I'll just put the bullets in right after the x-pipe.
Old Jun 13, 2017 | 05:15 PM
  #119
silplu83's Avatar
Hopefully it works, I'll be ordering some up if it goes well.
Old Jun 13, 2017 | 06:33 PM
  #120
WS6 #3392's Avatar
Do you have a recording of it now? I would like to hear what you have compared to the change.
