Anyone modify a Kooks TD?
#141
you should have no issues getting a 6" bullet in there
(we did it with the Billy boats & Hushpowers) .
The passenger side will fit with no modification, the drivers side needs a little adjusting towards the outer fender in an effort to clear the trunk cavity. The angle will make the muffler rub on the trunk cavity ... find a way to bend it out just about an inch & you have it.
Yeah, I just hate to return these mufflers without trying them.
The Magnaflows are 4" or 5" wide right? So I don't know why a 6" wouldn't work. I think the dude was just not in the mood to fight it.
I'm going to try this weekend to install them. Was hoping to just pay someone. Everything else on the car I've done myself and sometimes I just don't want to mess with it.
#143
#149
Super Hulk Smash
10db quieter at idle outside. 5db inside at idle.
Drones worse at 1500.
And is much louder above 2000.
Total bust. And I hacked up the exhaust to get those larger canisters to fit. They are longer and have much more packing. So I don't know? I plan to let them break in before I pass final judgement.
Exhaust tips are a little off now in order to make room for the canisters. So not touching. But at some points while driving, it sounded like it was. So I need to get under there and inspect closely after putting some miles on it.
However... it is deeper and drives nicer at 50 and 60mph. Just worse at 70+.
Considering how little room there is under the car, I have to give it to Kooks. They didn't do a terrible job with this exhaust for a mass market car with a history of being "off" from the factory on tolerances.
#155
Too bad, I agree additional bullets are probably the way to go. Wonder how bullets would work where the cats go for those who don't have them. Or even replacing cats with bullets if it would be quieter. The kooks cats are 10" long and ~4" around, not really any more room on the drivers side since the pipe flattens out after that.
#156
Super Hulk Smash
It was quieter tonight when I drove it. So there's hope that with a few more heat cycles through it, the sound will settle in.
I also need to make sure it's not vibrating gainst the floor. It's heavier now with the UltraFlos. But they are 14x6 straight through mufflers with packing. They should be quieter... lol
The db meter was showing about 5 db quieter in a lot of places (cruise at 60 was about 80-82 either way and 85-87 at 70).But like just accelerating... where it was 95-98 db in the car with the big stall and the drone areas was 95-98db... it was around 88-91 now accelerating and the drone is around 90-93... both lower. Just the drone was deeper. Overall, the sound is much smoother with less BLATBLATLBAT.
Really, it just needs a resonator to break up the drone. So, I'm going to work on getting the bullets in there in the cat areas. Those long pipes to the x-pipe are like megaphones.
#157
It's frustrating to put out the time, energy, hopes & money only to be disappointed.
I still can't get my head around why:
Larger can, more packing, sound canceling technology & these round mufflers can't make a significant difference in taming the system.
Hope they brake in & hit your goals.
#160
I went with MWC version of the DS loop. As mentioned earlier, MWC mounts from the top down. The BMR ( while a well constructed piece) hung just too low for my clearance. I'm shaving pancakes off the ground with my ride height.
Do you need it: I guess the thinking is, if you have the need for a 3" exhaust ... You probably have the power that's associated. At this level it is a valuable safety feature. I saw a DS break loose while a car was on a dyno ..... No joke to the destruction that was caused. If a person was in the middle of that fiasco it would have been "Lights out".
