Gen 3 to gen 4 conversion.
Old Sep 28, 2014 | 10:14 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Default Gen 3 to gen 4 conversion.
Ok. I decided to do a gen 4 ls3 for my next motor, and I know thanks to search the changes that I need, but does anyone sell everything together as one package?
Thanks.
Old Sep 28, 2014 | 12:45 PM
74u's Avatar
74u
Check out this kit...
https://sdparts.com/details/scoggin-...nter/sdlsck24x
Old Sep 28, 2014 | 12:46 PM
maroonls1z's Avatar
Scoggin dickey may have or can probably throw together all the harness converters you need if that's what your talking about?
maroonls1z's Avatar
Beat me literally by how long it took me to type that
Old Sep 28, 2014 | 02:15 PM
UNDER PRESSURE MOD
Well I know the front timing cover, valley cover, cam sensor, knock sensor harness all are needed. I didn't know if it was cheaper to buy it as a kit or separately. Thanks.
Old Sep 28, 2014 | 02:26 PM
74u's Avatar
74u
You could probably piecemeal it together but unless you are buying used parts the total is probably going to be pretty close.
And don't forget the precious damper...LOL
Old Sep 28, 2014 | 07:00 PM
UNDER PRESSURE MOD
I have the timing chain dampner on my current motor, so I can re-use it or sell it I guess. Maybe I'll contact them directly and talk to them since I already have the ls3 lifter retainers as well.
Old Oct 6, 2014 | 07:39 AM
metcalfm45's Avatar
I'm doing the same swap as well. If y'all don't mind me asking, why is the valley cover needing to be changed?
Old Oct 8, 2014 | 06:21 AM
UNDER PRESSURE MOD
On the Gen III motors, you have the knock sensors in the valley, but on the Gen IV motors, they aren't there, so you need a solid valley cover.
Old Oct 8, 2014 | 08:09 PM
S10xGN's Avatar
The bolt pattern/shape is completely different.
