Shorter Runners for FAST Intake!!!
Supposedly the cathedral LSXRT out-performed the LSXR on same engine so I'm very interested to see how it runs with L92 ports!
http://gmauthority.com/blog/2016/12/...s3-v8-engines/
In the last pic, you can see there is a little gap where the runner mates to the lower shell. This was only on the runner for the #1 cylinder. I think I can take it apart, fit it a little better, and reassemble to fix it.
That's measured from the top machined surface of the block where the valley cover sits.
With a 90mm TB, I'm betting it's totally be a wasted effort.
KW
BTW.....I suppose you would believe that a gain of 12 HP at 300 RPMs higher, and a LOSS of 15 TQ is a significant gain. I would disagree.
Also, horsepower and torque below the curve suffers with the HP runners versus the full length runners.
Jus' sayin'........
What is the displacement, heads and cam specs on
you're engine below that LSXRT?
1989GTA,
I posted results with the mid length runners in both this
section (0 replies lol) and the Dyno results section with
few replies/comments.
I can surmise from my results that to take advantage
of the mid length runners a combination should
reach peak HP @ 7000 RPM Minimum up to 7500,
and shifting @ 7500 RPM Minimum up to 8000+
So I would consider LLSR & Top Tier Heads at a
minimum. Have some thoughts on a killer 416"
street/strip combo I will post in the other threads
if there is any interest.
Jus' sayin'........
KW
