Shorter Runners for FAST Intake!!!
Old May 8, 2017 | 02:27 PM
  #221
Tuskyz28's Avatar
Originally Posted by big hammer
people wonder why they can't get ls3 ports to perform but then They refuse to rev them
Finally we agree on something
Old May 8, 2017 | 02:34 PM
  #222
big hammer's Avatar
If you're wanting to stay under 7000 rpm I'd be more apt to choose a cathedral based port.
Old May 13, 2017 | 06:22 PM
  #223
slogo's Avatar
Not sure if this has been posted yet. http://www.enginelabs.com/engine-tec...-a-runner-swap
Old May 14, 2017 | 02:28 PM
  #224
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Original info from Super Chevy July 2016 I believe.
Good technical info on the Runners.
Poor Test Engine to showcase the benefits/differences IMO.
Needed aftermarket heads and or LLSR and spin to ~7500 RPM
with stock displacement, or 4.00" Stroke 416" to ~7000 RPM
To see worthwhile benefits, not just my opinion.
Old May 15, 2017 | 02:24 PM
  #225
KCS's Avatar
KCS
Moderator
439whp and 392ft-lbs seems pretty soft for a cammed 6 speed LS3 with a FAST 102. I suspect that it had a relatively small duration cam. If it had a bigger camshaft, I bet the shorter runners would have shown greater gains on the top end.
Old May 15, 2017 | 05:00 PM
  #226
Pretty sure it was a 229/244 113 LSA Cam for Nitrous.
Old May 16, 2017 | 08:59 AM
  #227
Mercier's Avatar
I know I can lose by running a Hi-Ram on a 5.3 Suburban but I'm not going to write an article about it. The FAST mid and short runners may not be the answer but at least use them appropriately. That article, as written, is barely worth reading.
Old May 17, 2017 | 05:12 PM
  #228
spanks13's Avatar
Back in 2015 SpeedTigger posted up runner measurements of the Victor Jr L92 intake on yellowbullet.
The actual measurements go like this:
LS3/L92 Victor Junior runners with cross section measured at the plenum:
Outer cross section 3.100x1.250 with a 7.00-7.500 length
Inner cross section 3.110x1.210 with a 5.00-5.25 length
The runner length averages exactly the same as the mid length fast at 6.25".
I'm estimating actually that the runner volume on average is a bit higher with the fast intake. The plenum volume will also be larger on the fast than the single plane.
Does this mean that we should be camming these things nearly identically to what the single plane carb intakes like to see? That is going to mean much more overlap than a traditional LS3 cam which tends to be in the 10-18* overlap range for a street application...probably will want tighter centers with more like 25* overlap while trying to keep IVC in the same place or a little earlier (tough to do when adding lots of overlap).
The cam used in the comparison test no doubt was optimized for long runner EFI intakes.
Old May 17, 2017 | 05:25 PM
  #229
spanks13's Avatar
Anyone know why 05CTSV took the intake back off and sold it? What did he put on instead? I saw it in the classified section.
Old May 17, 2017 | 06:01 PM
  #230
Not sure it was ever installed, thought he took out the LLSR
before he ever installed the Fast Mid Length Runners,
unless I mixed him up with another member.
Old May 17, 2017 | 08:48 PM
  #231
Mercier's Avatar
He last dynoed with the hydraulic(BTR large displacement/stroker) cam and FAST intake with mid runners. Switched to the Holley Sniper intake. I think he got interested initially because it is so much more attractive than the plastic intakes but said it runs very well too. I am sure he will get some numbers with it soon.
Old May 18, 2017 | 08:27 AM
  #232
05CTSV's Avatar
Yep, I sold the FAST. It worked well, but I just don't care for the design of the fast intakes with all their miles of rope gaskets sealing the runners and two halves together. Too many points for leaks. I did go with a Holley sniper low profile for the ls3. It's runner lengths are comparable to somewhere between the fast race runner and mid length runner. My first impressions of the sniper, love it. It looks bad ***, came with the fuel rails, cross over line and rail fittings for damn near 1/2 the price of plastic.
Just from driving, seems identical to how the car drove with the fast intake.
Old May 18, 2017 | 12:53 PM
  #233
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
But... but... but... Chinese made!
That Sniper looks awesome!
Old May 18, 2017 | 01:03 PM
  #234
Rise of the Phoenix's Avatar
I'm curious how a sniper intake would do on my setup compared to the FAST 92/92 on the car now?
Old May 18, 2017 | 01:17 PM
  #235
Mercier's Avatar
What a reversal, eh? We're making the plastic one in the states(I think?) and the metal one comes from China.
Old May 18, 2017 | 06:13 PM
  #236
Dyno time.....
Old May 18, 2017 | 08:23 PM
  #237
I know I would have bought one over the Mid-Rise used on our TBSS if it was available at the time. The plenum volume and runner length is very favourable. I wouldn't be surprised if there is an impact on valve events to optimize these types of intakes.
FAST needs to come down to reality and accept that they are not the only game in town. That means a price adjustment.
Old May 18, 2017 | 11:00 PM
  #238
spanks13's Avatar
I am very happy with the intake for ~$850. It is an extremely nice piece.
Old May 19, 2017 | 07:59 AM
  #239
I don't foresee them dropping their prices. I'm sure their sales numbers are still in the sweet spot for their company.
