LS3 throttle body conversion
Old Apr 8, 2015 | 07:20 AM
2000WS6TA's Avatar
Default LS3 throttle body conversion
i did a little searching and didnt exactly find what i needed. im swapping a built LQ9 in my WS6 and i bought a set of L92 heads for it, now i need a LS3 intake, and a 4 bolt drive by cable TB. I know they make plenty of them but spending $400+ for a NW or fast tb just seems a bit excessive to me. i can grab a stock ls3 tb for pretty cheap so does anyone make a kit to make it a DBC or is there a cheaper alternative to the FAST and NW? and yes ive seen the ebay ones but im always skeptic of ebay parts.
Old Apr 9, 2015 | 09:51 AM
2000WS6TA's Avatar
well i guess thats a no lol. maybe ill get lucky and find a good deal on a TB in the classifieds.
Old Apr 9, 2015 | 01:45 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
It would cost way more to do a dbw conversion than to just buy a new 4 bolt throttle body. You would need a new computer, harness, and dbw pedal with tack module.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Apr 9, 2015 | 02:39 PM
2000WS6TA's Avatar
i think you may have misunderstood, or maybe i didnt explain it well. i dont want to make my car a DBW, the car currently runs using drive by cable. is there a way to remove to wire and gears and strap a cable and spring to an existing TB that is dbw. basically i want to take off the parts that signals the TB to open on a dbw and put the thing that rotates the TB blade on a dbc on it, not sure what its called.
Old Apr 9, 2015 | 05:54 PM
redbird555's Avatar
No the tb housings are very different. Not only that but the Fbody pcm needs to see an iac motor as well as a tps sensor. The tb housing is actually made to accept those sensors with a dbw setup it's all integrated into the "brain" of the tb. So in short there is no way to convert a dbw tb to cable
Old Apr 10, 2015 | 06:52 AM
2000WS6TA's Avatar
ok. thanks, just hoping there was a cheap shortcut.
Old Apr 11, 2015 | 06:24 AM
garys 68's Avatar
Get a cheap ebay 3 to 4 bolt TB adapter, keep your current TB?
Old Apr 13, 2015 | 10:42 AM
2000WS6TA's Avatar
anyone have experience using this? i have a ported Stock fbody TB, its going to be on a turbo car so i guess the TB size isnt a huge factor if you're forcing the air in anyway.
Old Apr 22, 2015 | 05:55 PM
CBM Motorsports's Avatar
We carry them in stock! It is probably the cheapest option for you at this point.
Old Apr 23, 2015 | 07:13 AM
2000WS6TA's Avatar
hey thanks! unless i score a sweet deal on a TB ill probably use this.
