HELP NEEDED LS7 - LS3 Oiltemp sensor
Old Jul 30, 2015 | 04:51 AM
Kenn Egtved's Avatar
Default HELP NEEDED LS7 - LS3 Oiltemp sensor
I build a LS3 in my 2007 Z06 and used the LS7 wiring. Everything works but i need to put my 2 wires for my oiltemp that normally was in the drysump on the LS7, to my 3-pin oilsensor/levelsensor on my LS3 oilpan.
What wires goes to what?
Old Jul 30, 2015 | 11:17 AM
Default Anyone?!?!
My 2 wires are brown and green/white.
Old Aug 3, 2015 | 12:23 AM
KENS80V's Avatar
The green/white wire goes to the "B" terminal of the 3 way connector and the other wire goes to the "C" terminal.
The "A" terminal would go to the ECM (C2 33) for the oil level signal if you were wanting to hook it up..
Old Aug 3, 2015 | 02:39 AM
Default Wiring
Yes i found a picture of it on Ebay :-)
Old Feb 13, 2021 | 12:42 AM
rkh38800's Avatar
Question Engine oil temp/level signal LS3
Does the green/white oil temp signal wire go to a different pin on the gray ECM connector or to the same pin as the oil level signal?
