Edelbrock Cross Ram
Kinda like running a Y-pipe exhaust to a single muffler that had dual outlets/tailpipes. That ain't really a dual exhaust.....right?
To me, the only solution that makes sense is dual independent air-filters to dual independent tubes/baffles to dual independent MAFs into the dual independent TBs.
KW
KW
KW
So I'm saying there's a chance.
If you use a OEM MAF.....that's the size of the inlet, and only 'X' CFMs of air will flow through that point. It doesn't matter how many tubes you split off after that point to feed 'X' numbers of throttle bodies. That single MAF in that single inlet will determine airflow into the plenum.
Unless you dual the inlets to feed the TB's individually, you're not increasing flow into the plenum.
KW
KW
