Throttle Cable Woes
The throttle is a 92mm unit I bought on eBay. Yeah, I know, eBay, but it was still almost $100, so it isn't super cheap either. Just not a $500 name brand. I have a couple of ideas of how to fix this:
1) I bend the throttle pedal bar to lift the pedal higher at idle for more travel.
2) I grind on the throttle body cable mount to effectively shrink the radius and pick up the slack with the adjustable cable bracket.
I don't really like either of these solutions, so I am looking for ideas. Anyone else with a similar setup ever check to see if your throttle opens all the way?
Is the throttle supposed to be partially-open at the start? I just put my phone on top of the air filter with some weights to stand it up and filmed it while I hit the gas with the car off.
I'm not certain if the mounting hole alone can define throttle ratio, or if the radius of the pulley itself must also change. I'll check this this weekend.
If anyone comes across this thread some point down the line, the issue was this: the dual spring setup in the throttle body was overpowering a spring that is built into the Bosch cruise unit by the battery. That spring is likely part of the traction control system, and allows the throttle pedal-connected pulley to turn independently of the throttle body-connected pulley if enough force is applied. I stumbled on the solution accidentally when I removed one of the two throttle body springs for test fitting. Now that the spring is out, I get WOT before the throttle pedal hits the floor (which is good, because floor mats can get in the way, and full travel is a bit of a stretch for me).
The top white, plastic pulley is for cruise control (ignore it). The middle pulley is the throttle pedal cable, and the bottom one is the throttle body cable. The first time I press the gas, it works as it should, but that is only asking for part throttle. When I go full throttle on the second pass, watch how the pulleys no longer turn in unison. Removing the second spring on the throttle body fixes this. It is supposed to be there for "increased control," but it clearly won't work with my car.
How did you remove the spring? I'm having the same problem.
Edit: I figured it out. Dude you're a life saver, thanks for posting this solution.
I pulled one of the tb springs which allows me 100% throttle but it doesn't have enough resistance to get me back 0% throttle. I'm gonna have to come up with another solution but thanks for posting this. It helped get me on the right track.
Now I've created a new issue. I think during all of the tinkering around that I must have stretched the spring in the traction control unit. When I pull the tb cable I can only get to about 4.4v. I can push the blade just a touch more and it will finally hit the bump stop. I think the tc spring may have lost some strength due to me pulling on it too hard. It also has an issue when using cruise control. Shortly after setting the cruise the "tcs off" light comes on and it sets the check engine light for the tps sensor. As long as I don't use cruise both issues never occur.
So I'm thinking replace the spring in the tcs unit (if possible) or just try another tcs unit from a different car. Thoughts?
Randomly I get the p0121 code and it disables my tcs. I found a couple other threads showing the 5v signal for the TPS is shared with the AC low pressure cut off switch. Apparently this is a "known issue" when running a performance camshaft and should be disabled in the tune. Hopefully I can get it retuned if a few weeks.
