Fel-Pro Gaskets
Old Nov 6, 2020 | 07:55 PM
Last 1's Avatar
Default Fel-Pro Gaskets
What’s do you guys think about fel pro valve cover gaskets ? I think there junk. I have been breaking in my new engine and have had the valve covers off 3 times adjust valves and every time I take them off I have to cut a section out of them to make them work once’s they get hot .Im running a BTR Valve cover gasket on the driver side no trouble.2 rounds of Driven break in oil and changed 2 Penns oil and Lucas ZDDP today For the 3 round .shooting to have it dyno next week . anyway anybody else having this trouble ?
Old Nov 6, 2020 | 08:15 PM
klinznilk's Avatar
Zero issues at all with these. Have been running them on boosted and non boosted motors with zero leaks
They do appear to be too long, but if your patient and work the gasket backwards, you can get it to go in. I thought that the gasket must have been an inch too long, but I ultimately got it to go. Took a while. I do like the GM gaskets better.
Old Nov 7, 2020 | 05:24 AM
Last 1's Avatar
how many time’s have you removed them to reuse them? they work alright the first time It’s when you try to reuse them.
Old Nov 8, 2020 | 08:42 PM
helicoil's Avatar
No issues here, been using these for several years on various engines. Don't stretch them when you push them in the valve cover channel..
Old Nov 8, 2020 | 08:51 PM
AgFormula02's Avatar
Put the gasket in the fridge or freezer for a little bit. It will shrink. Then put it in the channel on the valve cover.
Old Nov 9, 2020 | 07:50 PM
Last 1's Avatar
Look like you guys are having better luck than me with the gaskets. getting ready pull valve cover again tomorrow and adjust the valve. BlueCat will be tuning my car Thursday .
Old Nov 15, 2020 | 09:45 AM
RB04Av's Avatar
:shrug:
I don't have any trouble at all with them, once they're properly installed into the groove in the VC. If they're installed not standing up perfectly straight all the way around, there's not a chance they'll seal the first time, let alone any times after that. Not getting them in there PEFECTLY is about the only thing I can see that would cause trouble.
I don't think FelPro is any different from any other mfr about that. Only other ones I can specifically recall using were Mahle, and they weren't materially different in any way from the FelPro. Might have been a different color (brown instead of blue?) but other than that they were indistinguishable. Both seem to work just fine if installed correctly.
I use a bit of white lithium grease on them to help them slide in easy. Oil, trans fluid, gear lube, any other kind of NON-FIBER and/or NON-MOLY grease, silicone spray, etc. etc. etc. would probably work just as well. Just a matter of your own personal preference.
