What Engine oil for built LS3?
Old Dec 3, 2017 | 06:17 PM
turbotrks's Avatar
Default What Engine oil for built LS3?
What brand and what weight of engine oil would y’all recommend for an HCI LS3? 505 RWHP, 6-speed street use only...
Old Dec 3, 2017 | 06:34 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Cats or no?
How much spring pressure?
Gasoline or E85?
Built or SBE?
Old Dec 3, 2017 | 07:31 PM
BOLO's Avatar
Mobil One 15W50 and have fun!
Old Dec 3, 2017 | 08:03 PM
turbotrks's Avatar
Originally Posted by NAVYBLUE210
Cats or no?
Gasoline or E85?
Built or SBE?
-does have cats
-Not sure about spring pressure, But has BTR .660 springs
-Gasoline
-SBE
Is that what you run?
Old Dec 3, 2017 | 08:04 PM
KW Baraka's Avatar
H/C/I, only?
If the engine hasn't been opened up....go with what GM recommends.
If the engine has been opened up, go with what the engine builder recommends.
KW
Old Dec 3, 2017 | 08:14 PM
nitrousjunky's Avatar
If no cats then Valvoline 10w30 VR1.
Old Dec 3, 2017 | 08:42 PM
turbotrks's Avatar
Stock rotating assembly has not been touched, but I did forgot to mention that it has a melling high volume/high-pressure pump.
Old Dec 3, 2017 | 09:19 PM
I would use 5W-30 AMSOIL Signature Series, No need for more than
30 Wt for a SBE Street application. With no cats, significantly higher
Spring pressures and intermittent use, I would suggest Z Rod 10W-30 for
Higher ZDDP and anti rust, corrosion inhibitors.
Full disclosure, 28 year user & dealer of AMSOIL, The best synthetic oils
Available, Not just my opinion.
Old Dec 3, 2017 | 09:36 PM
turbotrks's Avatar
Ok thanks
Old Dec 4, 2017 | 04:13 PM
ColeGTO's Avatar
5W-30 in the cooler months and 10W-30 in the warmer months here in SoCal. Pick your favorite Full Synthetic.
The oil change intervals are FAR more important than the weight you choose.
Old Dec 4, 2017 | 09:04 PM
BOLO's Avatar
Default Mobil one 15w50
Originally Posted by turbotrks
-does have cats
-Gasoline
-SBE
Yes with my old combo(LT1)--when it was still street driven. In fact, Gm used Mobil one 15w50 on all their corvettes from the factory back then.
Now with my new combo, I run Valvoline VR1 20w50.
Old Dec 5, 2017 | 08:25 PM
GM specified 15W-50 for track operation of C7 Corvettes.
Not aware of any street/production spec other than
5 or 10 W-30 in any C4,5,6, or 7 in any pushrod engine
In the US (Excluding C4 ZR1).
Could you provide documentation.
