2006-8 vs 2009 TBSS intake differences? and TB selection?
Old Feb 19, 2018 | 12:12 PM
mikedamageinc's Avatar
Default 2006-8 vs 2009 TBSS intake differences? and TB selection?
I am looking at getting a TBSS intake for my SUV LS1 swap but I noticed that there is a different part number for 2006-2008 (12580420) and 2009 (12620308). Both use the same manifold and TB gaskets, same injectors, but different TB's, which I assume is tuning since they are the same size. It probably doesn't matter which one I get but just in case there is something that could change other part selection I just want to know. Both are super cheap from parts suppliers but the 2009 is slightly cheaper so I'll go with that if nothing else.
Also I'm looking at a 92mm TB cable driven, do I need to port the neck of the intake for a smooth transition since it is 87mm?
Old Feb 19, 2018 | 01:26 PM
pantera_efi's Avatar
Default DBW/DBC Conversion Kit
Hi Mike, make a DBW/DBC conversion kit for the GM 90mm Air Door.
The cost is $135.00, I have 90mm cores ?
Lance
Old Feb 20, 2018 | 07:56 AM
Lance
Im not sure what you mean, do you have a link?
Old Feb 21, 2018 | 11:45 AM
Default Drive By Wire to Drive By Cable Conversion Kit
Hi Mike, sorry.
I restate : I manufacture a kit to modify a GM 90mm Throttle Body.
The GM TB 90mm is driven by an electric motor, I remove that item and install a Throttle Position Sensor on a new mount plate including other internal items one such as a new Throttle Shaft, blade screws, etc.
Lance
Old Feb 21, 2018 | 11:57 AM
turboal1's Avatar
Default Int
Any late model 4 bolt truck int is the same
as a TBSS Cathedral port int. Stock T/B is 87mm
a 90mm LS3 will bolt right on.
Attached Thumbnails 2006-8 vs 2009 TBSS intake differences? and TB selection?-tbss-1.jpg
Old Feb 22, 2018 | 04:18 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I thought it was worth the effort to port it: https://ls1tech.com/forums/generatio...-approach.html
Old Feb 24, 2018 | 05:33 PM
So here is the difference if anyone cares. The pcv "in" on the top. 2009 has a hole, 2006-2008 has the fitting.
Old May 14, 2021 | 12:23 PM
Project101's Avatar
Originally Posted by pantera_efi
Hi Mike, sorry.
Lance
Do you still offer this service/kit? I tried to PM but was unable.
please PM if you can .
Old May 14, 2021 | 03:07 PM
RedXray's Avatar
Just to add the MAP sensor hold down and sensor sealing o-rings are also different.
Old May 14, 2021 | 04:43 PM
I don't think Pantera EFI is a member here anymore.
Old May 15, 2021 | 12:03 AM
Project101's Avatar
Well shoot.
Old May 15, 2021 | 01:58 AM
1FastBrick's Avatar
Originally Posted by Project101
Well shoot.
If you put his user name together as one word followed by .com you can find his website.
It is limited but you can contact him through there.
Old May 24, 2021 | 06:11 PM
tmcmillan5's Avatar
Ok while everyone is talking about this 2006-2008 intake can anyone tell me how to / if I can remove and re-clock that PVC fitting ? I'm trying to install a catch can and it would help routing the hoses.
Thanks, Tony
