Giant LS3 Intake Manifold Dyno Shootout!
Old 04-07-2018, 10:12 PM
  #121
spanks13's Avatar
Well it made more power than the fast in the test...
But anyways, I bought an ls7 so I’ll be returning it I think.
Old 04-07-2018, 10:24 PM
  #122
Received 3,190 Likes on 2,492 Posts
Only at the peak. It loses low and mid power in wholesale quantities.
Old 04-08-2018, 08:20 AM
  #123
HioSSilver's Avatar
If you're not racing at 3-4k rpm then it's ok to lose a little through there.
Old 06-16-2018, 05:26 PM
  #124
AINT SKEERED's Avatar
My 4.10 gear and 5000+stall will take care of low end and midrange tq on a 427.
looks like the sniper will do great with a low lash solid roller shifting around 7500
Old 06-18-2018, 11:20 PM
  #125
big hammer's Avatar
Originally Posted by AINT SKEERED
My 4.10 year and 5000+stall will take care of low end and midrange tq on a 427.
the sniper surprised me. Look like a good compromise of TQ for HP and it’ll go to 8000
Old 06-18-2018, 11:43 PM
  #126
Tuskyz28's Avatar
I'e heard nothing but good things about the LS3 intake with the radius mod did to them. Heard they do as well as some of these aftermarket intakes.
Old 06-19-2018, 07:32 AM
  #127
yeah it looks promising. I will be going that route. Using the short version
Old 06-19-2018, 03:14 PM
  #128
spanks13's Avatar
I returned my LS3 sniper for the LS7 version when I picked up my new engine. My engine combo needs to make real power to at least 7700 - I think it should work well. I'll likely plan to shift 7800-8000rpm.
Old 06-19-2018, 04:15 PM
  #129
how was the quality of the sniper intake and which version ls3 intake was it?
Old 06-20-2018, 07:35 PM
  #130
spanks13's Avatar
It was the low pro. Build quality was very nice.
I only set it on the engine to see things like hood clearance. I don’t know how good the port match was.
Old 06-20-2018, 07:44 PM
  #131
Good to know. It will be sent to sps before my heads ship to port match
Old 06-21-2018, 07:29 AM
  #132
https://www.lsxceleration.com/gm-ls3...-w-fuel-rails/
is this the same as holley low profile? Looks identical just rebadged.
Holley seems to have back order on the sniper low profile until late July.
Old 06-21-2018, 10:38 AM
  #133
stevieturbo's Avatar
More than likely, there's a few resellers of the Chinese stuff. Main difference seems to just be Holley's logo stamped into them
Old 06-21-2018, 02:19 PM
  #134
HioSSilver's Avatar
Idk...I bought a chinky town version of the ls7 sniper style intake and it was awful. Gonna make a super cool coffee table out of it
Old 06-21-2018, 03:47 PM
  #135
yea I thinkI'll wait for the sniper
Old 06-21-2018, 06:13 PM
  #136
The Sniper is Chinese too, so don't think it will be superb quality
Old 06-21-2018, 09:51 PM
  #137
Other than your post stevie not many other complaints that I see for the price
Old 06-22-2018, 03:43 AM
  #138
Maybe most had lower expectations, or simply didnt look closely enough at them ?
But I do agree, for the money they do still represent decent value. But it cannot be ignored that the quality is seriously lacking.. Port alignment on mine was terrible ( cathedrals )....but how many stick a bore scope inside the manifold to look ? Probably few.
The rubber o-ring seals provided are poor, but I did use them and I do believe they will seal. But they are nowhere near OEM quality.
And certainly on my fuel rails, on one end of each rail the taper at the end was insufficient for the o-ring fitting. So upon tightening it destroyed the o-ring. Now it did remain squashed enough to prevent leaks ok but when I removed everything again, the o-ring was not in any way usable again. That's potentially a serious issue which long term could and probably would result in leaks.
For refitting I tried a 0.5mm thinner o-ring and this seemed to fit much better and so far no leaks. But the other end was fine with the supplied o-rings which are correct for the -8 fittings.
And then there is the noise...the sound transmitted via the thing sheet metal lid of the intake really is terrible. Of course when driving, inside the car etc etc I wont hear this. But with the hood open and engine idling it really is shocking. That again is a quality issue
But I will use it for now, it gives me a good baseline as to what height of such intake will fit my car etc should I decide on a proper one later and as to whether it will genuinely help me in the 7k+ range without spending a fortune to find out.
And yes they do still look cool.
But be under no illusions about the quality even if they are very cheap. Although how anyone can fabricate and supply all the parts even at the level they are for the price, is no joke either. Without doubt there is a lot of work in fabbing these things.
Old 07-01-2018, 12:39 AM
  #139
dmracing's Avatar
I’m partial to this intake
Old 07-01-2018, 01:15 AM
  #140
It wont fit under my cowl. I'd prefer it as well
yeah I wish it fit my car
