Need help with dyno critique
Buddy on tech here also gained like 70 rwhp once by removing plugged cats
Without knowing what cam is in the car, nobody can help you.
The curve looks like a stock cam. Maybe stock for something else; but stock behavior nonetheless. Peaks at about a typical RPM for stock, etc.
Exhaust restriction typically creates more of a "wall" look; the flow reaches a point, and stops. The curve just craters rather than tapering off like that one.
As far as second-guessing about what "someone" "would do", especially if that led you to the conclusion that what they did made sense somehow or is the same as what you would do, I gave up assuming that sort of thing about the human race a LONG time ago.
People do stuff that makes no sense to me all the time.You could put a dial indicator on acoupla push rods and get some kind of idea what it is; maybe not down to the part #, but a rough clue, at least.
* not sure if L76? Ever had vvt
