Rear Cover Leak
I got a new cover on the way and gonna try that. Also gonna check alignment of oil pan with block due to was leaking when I got car so may have never been lined up right.
Are you using the SSC Alignment tool that involves removing crank seal, and goes inside cover, or the one the goes inside the installed seal?
Where exactly is it leaking at?
the rear of the oil pan must align with the block also ....meaning it cant protrude past the block and interfere with the bellhousing of the tranny
https://ls1tech.com/forums/generatio...-critical.html
