Tranny oil cooler question
Old Nov 29, 2018 | 02:42 PM
JimLev's Avatar
Default Tranny oil cooler question
Does this quick disconnect fitting unscrew? I've had the left side in a vise but the fitting won't budge.
I picked up this tranny oil cooler at the junkyard last week, want to use AN6 fittings on it like I did on my4L65e tranny.
Old Dec 1, 2018 | 02:00 PM
JimLev's Avatar
A little heat from my torch softened up what ever GM was using for a thread seal.
They unscrewed very easy.
I'll be using a 3/8 NPT to AN6 elbow like.
http://www.earls.com.au/shop/earls-9...6-to-38-npt-2/
Old Dec 1, 2018 | 02:19 PM
Cool! Looks like you're on your way to tranny-cooling bliss!
Old Dec 2, 2018 | 07:20 AM
01ssreda4's Avatar
better have a ton of airflow over that and be running a stock converter
Old Dec 2, 2018 | 07:50 AM
JimLev's Avatar
This is my first build using an automatic (4L65e), the torque converter isn't the one specified for this tranny which has a stall speed of 2400-2800. I'm using the one specified for the 4L70e that has a stall speed of 3000-3400. This one was recommended, it can take more of a beating, plus the car will only weigh 2400lbs.
