When to do a Trunnion kit? Better options?
Old Jan 27, 2019 | 09:45 PM
InfamousRacing's Avatar
Default When to do a Trunnion kit? Better options?
2009 LY6, Summit 8716 cam, TFS-2500286 spring kit. Wondering if a trunnion kit should be installed? Is there a better, affordable, rocker arm kit? The vehicle will be driven on the street and track, plan to run nitrous at the track if that makes any difference. Let me know if you need any other information and thanks in advance!
Old Jan 27, 2019 | 10:21 PM
How many miles on the engine? If over 100k, I would consider it. And probably get a bronze bushing type; MOST caged needle ones don't have a good track record, only because the trunnions themselves were not properly heat treated and wore prematurely.
The only good needle bearing kit I have heard of is from WS6store as their bearings have their own inner race. Theirs IS worth considering.
Old Jan 28, 2019 | 06:41 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
When to do a trunion kit? I'd do it on a bone stock engine, myself. Some fail completely stock. A LOT don't, but I don't like those odds.
Not a fan of needle bearings. I'd be looking at the Straub, Smith Brothers, or my preference, CHE kits.
Old Jan 28, 2019 | 07:02 AM
qweedqwag's Avatar
I installed a CHE kit on my 346. seems to work like it was intended to.
Mike.
Old Jan 28, 2019 | 02:33 PM
gnx7's Avatar
For a little over $100 you can get the BTR kit and it is cheap insurance..... when you press out the OEM parts you wouldn't believe how easily they pop out.... now imagine spinning that at high RPM with a bigger cam than stock. I do it in ALL the motors that touch my hands.
Old Jan 28, 2019 | 02:40 PM
As long as the BTR kit is bushing type and not needle bearing, then OK.
Old Jan 29, 2019 | 09:26 AM
hellbents-10's Avatar
Seems like the stockers last much longer then all of the aftermarket "fixes". If they have a pile of miles on them then I put in the bushed type.
Old Jan 29, 2019 | 10:47 AM
The stock ones do last a long time. WHEN they do. When they DON'T, you have little bitty needles going everywhere, usually where you DON'T want them.
Old Jan 29, 2019 | 10:55 AM
Thank you all for the replies. I'll definitely put in a kit in. I assume the engine has about 240k miles on it when pulled from a boxtruck. I stripped the engine down to bare block and did all new bearings because of lower than normal oil pressure. The BTR kit uses needle bearings but they are caged and they say it's a completely different design than stock. It's about $50 cheaper than a bushing style kit. Is there quite a bit less resistance in the bearing style? Does anyone have a link to the WS6 kit that works for this engine?
Old Jan 29, 2019 | 11:02 AM
What you need to watch for is if those caged needles still use the trunnion for the inner race. That's where the trouble is. There was a problem with improperly heat treated trunnions being too soft, with the result of needle bearings digging into them and wearing prematurely. A GOOD needle bearing kit will use TOTALLY caged bearings, with their own inner race.
Old Feb 11, 2019 | 02:46 PM
Summitracing's Avatar
LS1Tech Sponsor
We have both the bearing and bushing style kits available. Here's the bushing style one: P/N SUM-141560
__________________
800-230-3030
www.SummitRacing.com
Old Feb 11, 2019 | 03:01 PM
Wink
I installed your bushing style kit last night
Old Feb 11, 2019 | 03:05 PM
LS1Tech Sponsor
Great! Congrats and you're good to go.
__________________
800-230-3030
