alternator is not charging when fan is on
i have an issue with my voltage dropping to 12.8 or even below when my fan is on and it keep killing my battery, the alternator is from 19370821 i think, its wired with one wire from the engine harness, the fan is from ford taurus which pulls 30-40 amp.
this voltage drop causing all kind of issues and its bothering me,
i dont think its the alternator as its not that old barely used less than 1000 mile on it, it been in storage most of it time mostly of because of this issue, could it be the one wire connector or maybe psi thin alternator to starter wire which is what powers the whole car or is the taurus fan draw too much amp for the alternator
You can run a modern GM alternator to add a lot of extra oomph. I just did on my 5.3L Colorado, boosted alternator by 100amps production rating just by using a current model one, all direct from GM or Rock Auto, not a black magic shop that says high output. My alternator went from like 140 to 240 amp rating. Same size, same connectors, same everything. Plug and play. Hate to hear you not using the ride because of it. I work for the company that makes the current GM LS mass production ones, so easy for me to know what fits/works. Mine was truck accessory drive, FYI.
I have a 50 page alternator thread full of my posts and other peoples posts about alternators failing right out of the box and all the replacement alternators for F bodies being absolute junk.
Upgrade to the 145 amp truck alternator and be done with the issues.
https://ls1tech.com/forums/generatio...failure-s.html
I ran a 2000 Mustang GT fan* on my '89 Firebird because I happened to have one lying around. It cooled great, but I had a lot of problems with relays not being able to handle the amperage, and the factory 105 amp alternator couldn't cut it, so I had it upgraded with a 160 amp kit. This fan immediately melted the factory fan relay, and I dicked around with some 70 amp universal relays for awhile, before finally settling on a Bosch 75 amp relay with 8 gauge wiring.
*Taurus, Mustang, Crown Vic, Thunderbird, etc. all use the same fan with different shrouds.
I believe what he was referring too is the Ford solenoid is just that, a solenoid, which is a relay, low current controls high current.
To answer the question what the Ford solenoid is rated at, that I don't know. I've been using it to control high amp fans for years as many people have.
Andrew
Andrew
do you know how much the alternator output with and without the s terminal ?
I would still add a ground to the block from the battery.
Andrew
