LS7 fuel rails, TB, injectors onto LS3/L76 intake?
Loaded LS7 intake, fuel rails, injectors, throttle body $350
https://www.summitracing.com/parts/nal-12644568/?rrec=true
Loaded LS3 intake, fuel rails, injectors, throttle body $893
https://www.summitracing.com/parts/nal-12674428
LS3 intake no parts $215
https://www.summitracing.com/parts/ado-12686561?seid=srese1&gclid=EAIaIQobChMIjYj-zuOh5AIVw5JbCh2r7gYuEAQYASABEgId6fD_BwE
So.... Can I buy a loaded LS7 intake and swap the rails, throttle body, injectors etc onto an LS3 intake?
Im still money ahead and have a 93mm throttle body.
Will the parts physically bolt up, any issues with 93mm throttle body on LS3/L76 intake. Can i get a tune on this. What MAP sensor. Im building an LY6.
Am I crazy, well, yes. But, will it work?
I don't believe the LS7 rails will work on the LS3 intake. When I bought an LS7 style MSD, I had to buy LS7 rails as I was told LS3 rails would not work - IIRC it was said the injector angle was different.
Looking for the best combo of parts. If you do the math, the combo would have been around $550 for the whole set up VS. $900 for a loaded LS3.
I picked up a new take off LS3 without throttle body since I started the thread. Time to decide - stock or aftermarket TB.
