Rear Steam Tube Fast 102
Not bashing the nitrous outlet kit but I had nothing but trouble with leaks from the machined aluminum blocks. What I ended up doing was using a stock front mount crossover tube on the rear as well and ran a rubber line to the front
Did you contact us? did you use sealant on the fittings?
No issues with mine from Nitrous Outlet. I dabbed a little RTV sealant when I reinstalled the setup. The only problem I get is street racers thinking it's a Nitrous solenoid.
Steam vent msd ls7 intake
Do the nitrous outlet kits work for the msd ls7 manifold. I know it is tight back there. This is also for c6 Corvette. I also know msd does not have a lot of room under it maybe 1/4 inch at best and shaved heads probably less.
We currently have one in development! We'll have it together by Black Friday.
