Who ports throttle bodies
Old Nov 4, 2020 | 02:17 AM
LS1TAUTO's Avatar
Default Who ports throttle bodies
Who offers the service?!?!
Old Nov 4, 2020 | 07:06 AM
Double06's Avatar
Tony Mamo, Peak Speed Shop out of Colorado, VMax Motorsports
Old Nov 5, 2020 | 04:55 AM
SteveJewels's Avatar
Veteran: Navy
Soler Performance
Handy link to Soler Performance
Old Nov 5, 2020 | 05:39 AM
showdog75's Avatar
Pretty sure Vengeance Racing does as well.
Old Nov 5, 2020 | 03:04 PM
Call Tony Mamo. He’s 320 miles south of you. One of the best airflow engineers in the country.
Old Nov 6, 2020 | 08:27 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
What TB are you needing ported....I have literally done thousands of GM TB's over the years.
The only things Im not porting anymore are the original 78mm LS1 style TB's. They require epoxy and a whole bunch of work for a TB that still flows only a modest amount of air.
Its better to step into a ported 90mm LS2 at that point
Anyway....PM or email me directly regarding what your needing and we can go from there.
Tony@mamomotorsports.com
Regards,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Dec 27, 2020 | 07:39 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Go with Mamo. Night and day difference between stock and his work. He did the one on my old 2012 CTSV and it completely got rid of the throttle tip-in lag it had.
Old Jan 7, 2021 | 10:14 AM
ramairjohn2000's Avatar
Will ls2 throttle body bolt up to ls6 intake or any idea which would be recommended? Thanks in advance
Old Jan 7, 2021 | 11:11 AM
Do more homework. It would tell you the LS6 TB is 3 bolt, and the LS2 TB is 4 bolt
What are you trying to do?
Old Jan 7, 2021 | 11:20 AM
I did look and found ac delco ls6 3 bolt 75mm throttle body basically I’m trying to improve airflow improve all while keeping my ls6 intake
Old Jan 7, 2021 | 11:33 AM
Sacrilege's Avatar
BBK is about your only option for LS6 intake.
Old Jan 7, 2021 | 05:11 PM
How big an engine are we discussing here? That and cam/heads will determine TB size.
Old Jan 7, 2021 | 09:03 PM
plain old ls1 lol stock heads and cam but will be upgrading hopefully soon
Old Jan 7, 2021 | 09:07 PM
To WHAT?? Once you know that will you know how big a TB you need.
Old Jan 16, 2021 | 08:09 PM
qweedqwag's Avatar
Tony,
Can an LS2 TB be converted to a cable pull?
Mike
Old Jan 17, 2021 | 06:37 AM
Default Upgrade
bsucally bigger cam and 243 heads hopefully but keeping stock block
