Stripped threads on block for bell housing...
I actually don't think that hole is very critical. The larger upper ones do all the work.
Still, to fix it, Heli-Coil is your friend
Are you running a manual or automatic transmission? If automatic, remove the pilot bearing.
+ Time-Sert Professional Thread Repair Kits & Inserts American & Metric + (time-sert.com)
Print out a couple copies of this torque spec sheet and put them in your tool box and give to your buddies that have LS projects: http://ls1howto.com/index.php?category=1
I will look into getting a kit from them. I'm sure this won't be the last time I strip threads.
Legitimate question. The bolts are from the supplied QuickTime bell housing kit (RM-8019). They are the correct ones to use. I simply overtightened the bolt. This is, without a doubt, my screw up.
