Excessive oil in catch can after DOD delete
Engine is a 6.0L in a G8 with about 70k miles. I just did a DOD delete and cam swap on this motor including replacing all the fun stuff that goes along with that. I haven't been able to put too many miles on it so far, but took her out last weekend and romped on it a bit. On my way home I noticed it seemed to stumble a bit when I got on it and then tons of blue smoke comes out the back. No codes, runs fine otherwise. I thought for sure I blew the motor but first thing I did was check my Elite Engineering E2 catch can and it was FULL of oil (not what you'd see from vapor, but looked like it came straight from the bottle). I just checked it maybe 100 miles prior and it was empty. So I was obviously pulling oil into the intake which was evident when I pulled off the TB and saw all the oil in there.
Here are a few variables that occurred when I did the DOD delete that affected the oiling system or PCV:
- Went from a UPR catch can to Elite Engineering E2
- Swapped to the revised drivers side valve cover with improved baffling. Confirmed there is a restriction orifice in the hose barb
- Added a Melling 10296 oil pump with factory installed relief spring
- Plugged the DOD pressure relief in the pan
My thought was that the 10296 pump is pumping more oil up to the rockers and is causing it to get sucked into the catch can. I logged oil pressure with my TorquePro app and no excessive pressure was noted.
Prior to the cam swap, with the UPR can, I'd get maybe a 1/4 of oil in it after 4k miles.
Cylinder walls were smooth and no excessive wear noted. I'm having a hard time believing this issue is related to rings or other internal engine issues since it was much more oil that I think you can attribute to blow by.
I am contemplating swapping to an LS3 valley cover, moving the catch can inlet to the PCV orifice on the LS3 valley cover and plugging the barb on the valve cover.
Thanks in advance.
I also have the 10296.
I think that's the route I'm going to go then, with the LS3 valley cover and plug the valve cover port I've been using.
