Ls3 swap catch can/pcv questions
I’m ls swapping a 350z, and would like some input on the best solution.
I’ve got ports on both valve covers, valley cover, and one on both side of the intake manifold behind the throttle body.
Previous owner of the engine had a catch can with two inlets and one outlet with a check valve on it.
He had one inlet tied to the passenger side valve cover, the other to the valley cover, and the outlet to the intake on the passenger side.
Then he just had the drivers side valve cover and intake manifold tied together.
Is there a better way?
From my research it looks like the valve covers Instead need to be tied into a fresh air port after the maf on the intake tube. Then the valley cover to the catch can and then to the Intake. Then that leaves the drivers side of the intake manifold open, in that situation. Best to cap it and if so with what?
Or is there a better way to route everything?
Heres what you're looking for. Put the catch can (unvented) on the blue line between the valley cover PCV and the intake. Cap any other ports on the intake as they will just be vacuum leaks. I'd use the stock valley cover as the PCV is well baffled. I prefer the Radium Engineering catch can as its simple, clean, easy to empty, and includes a dip stick to check the volume of fluid as it accumulates.
http://www.radiumauto.com/Catch-Can-...gine-P956.aspx
Wouldn’t want to tie those into where the stock evap went right?
The valve covers simply need a source of filtered fresh air....which could be as simple as a valve cover breather with a filter element.
The crank case, needs to see vacuum. Typically, this involves a baffled PCV valve connected to the intake or a vacuum port in order to ensure the crank case is seeing vacuum without sucking oil into the intake. If you want to be sure no oil enters the intake, a catch can can be added to this line.
Even first generation small block Chevy's had a PCV system of sorts....the valley was vented to the intake and the crank case had a draft tube.
If you dont run a PCV, you'll see significant oil transiting past the rings and burning in the combustion chamber....not to mention the pressure build up in the crank case with will push oil vapor past all of the seals in the motor, eventually coating the engine and engine bay in a film of oil.
But sure, we can "agree to disagree".
It does nothing for ring seal or blowby.
And that's the downside of the whole thing. Would be better with vacuum on the crankcase, but probably not worth fretting about unless you see a problem. Most of us aren't pushing our cars hard enough to matter. And it's really quick and easy to reconfigure PCV for the track if you want.
Speed density tunes don't need to worry about this stuff.
Hell even the fuel you use can have an impact, E85 is hydroscopic and your burning it at higher volume and usually at a lower temperature so you either need to bring the engine fully up to temperature every time you start it or you should probably run a PCV system.
I run E85 in my S10 with a PVC but it was meant to be driven daily, On the other hand my Son in-law runs his just vented but it's not driven as often and get oil changes more often.
As a side note, I started an engine on the run stand a few times when the temp inside the garage was in the 50's and it didn't get fully warmed up every time and it milked the oil, Had I had a PCV system running it would not have and it would have saved the trouble of flushing the engine a couple times to get it all out.
The amount of air going into the intake from the the PCV is a predetermined number that is a programmed offset in the ECU and only under vacuum, If what you are saying were true then how does the ECU know how much blowby is being pushed into the intake as the engine wears and the amount changes over time....it's being pushed past the rings and the ECU has no way of measuring it.
I've ran them that way and never changed the tune and never had any issues of any kind and yes it was a stock tune, I prefer not having excess crankcase pressure running through the intake underload, It does nothing but contaminate the incoming charge.
