Looking for inputs on coatings for headers
Old Jul 21, 2021 | 05:00 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Looking for inputs on coatings for headers
I am looking for inputs on a heat shield coating for the headers that I am buying for my build.
- This is a daily driver, and damage/discoloration to the coating matters, so Swain Tech isn't going to happen.
- Is there a real world difference between 1000, 2000, and 2500 degree coatings?
Old Jul 21, 2021 | 09:41 PM
Google “Zycoat”. I’m going this route. NOT cheap.
Old Jul 22, 2021 | 08:35 AM
RB04Av's Avatar
Yes there is definitely a difference among the various temp ratings.
In general, the higher temp ones aren't as visually appealing; I guess a certain amount of that gets traded off for the other property. At some level, you gotta choose what fits your application the best.
For yerbasic N/A car headers, the 1000° is adequate. Headers rarely get above about 800°, and usually not that hot. For a turbo or the like, maybe you'd want more though.
I've usually used Jet-Hot; not the "highest tech" option out there maybe, but seems entirely adequate for the task at hand. Their "silver" coating (it's not their "high temp" product but I can't recall the rating) lasts a VERY long time on stainless steel. I highly recommend stainless over regular steel, for 2 reasons: the corrosion resistance (duh); and, the heat conductivity of stainless is only about 40% of regular carbon steel, which by itself reduces underhood temps. Ceramic coated stainless headers radiate relatively little more heat into the engine room than manifolds do. Most stainless alloys that are suitable for exhaust, will corrode to a certain degree; they're not utterly "stainless" exactly, but at least they don't rust into a pile of flakes either.
I got Jet-Hot's higher-temp coating one time on some mild steel headers, many years ago. I was a bit disappointed in it. It was very rough, almost like sandpaper; and the metal still eventually managed to corrode underneath it and blow it off, over time. That may have been an attribute of the base metal and not the coating though. But, it stained kind of alot, like if oil dripped on it or something, where the "silver" is easier to keep clean.
Old Jul 22, 2021 | 09:14 AM
1bdbrd's Avatar
I have been looking into Swaintech coating for a new set of headers for my car. I know you said they are out because of the coloring but I have read many places (I think even on their own website) that after they are coated you can spray paint them with high temp black paint if you don't like the white without any sacrifice to the coating performance.
I also think I want to do some heatshield products heat shields on the firewall and under the car on top of the coating to help direct heat down and away from the interior.
But I am interested in where this thread can go.
Old Jul 22, 2021 | 09:17 AM
MixedE36's Avatar
I used Jet-Hot. But, a large factor for me was price and they are local so I could drop off my headers.
Old Jul 22, 2021 | 10:07 AM
FCar2000TA's Avatar
Veteran: Air Force
They must be owned by Hushmat. One of their contact e-mail addresses is at hushmat.com
I sent them a message to see if I can get a lower price if I have the new headers shipped directly to them.
edit: Yep, they are Hushmat. "ZyCoat products – made in the United States – are natural extensions of the industry-proven, auto enthusiast-preferred products from HushMat"
https://pitstopusa.com/b-96296-zycoat.html
Old Jul 22, 2021 | 05:20 PM
You are correct sir.
Old Jul 23, 2021 | 07:35 AM
showdog75's Avatar
I wonder how the zycoat holds up? I'm about to completely re do my exhaust with new headers and have considered Swaintech but this sounds much more convenient.
Old Jul 23, 2021 | 08:26 PM
Ive seen this used a good bit in the Pro-Touring world, and it seems to be working great and lasting also. A lot of those guys beat the crap out of their cars in Autocross and time trial events, so it’s getting abused pretty good without issue.
Old Jul 23, 2021 | 09:38 PM
pdxmotorhead's Avatar
I've had really good luck on sprint car headers with the "silver" ceramics, had it done by several places and never noticed much difference. of all the colors it seems to work among the best. Nothing like having to wrench on a motor that spent the last half hour at 9500 rpm's the coating made a remarkable difference over bare metal.
Old Jul 27, 2021 | 04:33 PM
FCar2000TA's Avatar
Veteran: Air Force
Ordered the Zycoat coating today. They are not much more than Jet-Hot, and the coating is polymer based, not powder or ceramic.
Old Jul 31, 2021 | 09:18 AM
showdog75's Avatar
I also ordered some zycoat a few days ago. It was 20% off then not sure if that still applies. I opted for the aerosol as I'm not setup for a paint gun. Hopefully I can update soon with pics.
Old Jul 31, 2021 | 11:01 AM
FCar2000TA's Avatar
Veteran: Air Force
I am going to have them do the coating. Having the headers shipped directly to them.
Old Jul 31, 2021 | 12:16 PM
showdog75's Avatar
If you don't mind me asking what kind of price did they give you?
Old Jul 31, 2021 | 12:33 PM
FCar2000TA's Avatar
Veteran: Air Force
The quote was over the phone since I am having the headers shipped directly to them. I don't remember exactly. I am pretty sure it was under $550 total.
Old Aug 3, 2021 | 07:26 PM
showdog75's Avatar
Got my headers for the hot rod and the driver's side exhaust manifold and a downpipe for the Duramax blasted and primed with the Zycoat. 8 hour air cure and first thing in the morning I'll hit them with color then bake for cure. I like the way the primer laid down, fingers crossed.
Old Aug 4, 2021 | 08:18 AM
showdog75's Avatar
Headers and truck pieces are finished. The silver looks good but the black is super slick. Wish I would've done the headers in black as well. I just hope it holds up. Time will tell.
Old Aug 4, 2021 | 04:22 PM
rkupon1's Avatar
Defly looks nice. Im interested in how well it holds up and the heat in.
Old Aug 4, 2021 | 05:52 PM
showdog75's Avatar
They claim a 40% reduction in surface heat. Sounds optimistic imo but I hope so.
Old Aug 4, 2021 | 06:28 PM
RB04Av's Avatar
This is what the Jet Hot "silver", on stainless, looks like after acoupla years. Maybe 2 - 3 years and 30 - 40k miles. (yeah, long commute) It's an old photo but should give an idea.
